Need Help!! Backup Lights!!!!!!
Old Jan 22, 2008 | 05:22 PM
  #31
79f250460's Avatar
79f250460
ok.....found the problem...
the white pink wire that is shown in manuals is not white pink on mine.....its purple white from the fuse panel for back up lights......
someone used that wire to go the the electric choke.....
the white pink wire that is there I have no Idea where to put it.....traced it from the NSS even though its wrong or I use two wires....and it goes through the interior and back out to the driver side engine bay to through connectors and to some thing sittin under the EGR it sits on there like a plug that goes to a temp sensor.....
there is a few other wires disconnected there that I have no clue where to put them...
Old Jan 22, 2008 | 05:28 PM
  #32
Mil1ion's Avatar
Mil1ion
The wire from the fuse panel goes to this connector
Old Jan 22, 2008 | 05:37 PM
  #33
greythorn3's Avatar
greythorn3
is that cotton wood all stuck to the oil on that engine?
Ray
Old Jan 22, 2008 | 05:59 PM
  #34
79f250460's Avatar
79f250460
where should the wire go to eventually from that dome thing in the picture....Mil1ion below your transimission vacuum lines?
should the choke just come from the alternator?
Old Jan 22, 2008 | 07:19 PM
  #35
Mil1ion's Avatar
Mil1ion
Ya... cottonwood fluff
The electric choke wire runs to the STATOR terminal on the alt.
from the connector
One Set of wires goes to the NSS on the trans and other set run in main harness underdash.
Old Jan 22, 2008 | 08:36 PM
  #36
79f250460's Avatar
79f250460
I dont have the connector is there any wires doubled up?
Old Jan 22, 2008 | 09:09 PM
  #37
Mil1ion's Avatar
Mil1ion
Is this a 79 automatic ?
Old Jan 23, 2008 | 07:43 AM
  #38
79f250460's Avatar
79f250460
yes....
there was a lot of wires cut around there and they had the NSS had wired in instead of a connector...
black & blue 78/9
Apr 7, 2016 06:35 PM
hankviii
Feb 7, 2016 10:42 PM
Jageesey1
Dec 23, 2015 03:08 PM
ligito
Mar 3, 2015 03:34 PM
dyoungen
Jun 5, 2013 07:27 AM
