Ford Keyless Entry Installation
Old Jan 5, 2008 | 05:52 PM
dc2842002's Avatar
dc2842002
I figured the relays out today and got them wired up. Now all I have to do is find the wires I need to tie into. I found a constant power source and the parking light wire. All I lack is the horn, dome light, door lock, and door unlock wires. I know all of the colors but have not found them yet. The lock and unlock wires I really haven't looked for yet. The horn and dome light are the ones that really have me stumped. The wiring diagram says that the horn wire can be found to the right of the steering column on a 6-way connector. I could not find this connector. I assume it is under the hood. The dome light wire is supposed to be in the Rear of Driver's Door Sill Plate Harness. I can't find this harness. I found the parking light wire at the switch and though I would find the dome light wire there but didn't
Any info on the location of these wires.
Old Jan 6, 2008 | 04:28 PM
dc2842002's Avatar
dc2842002
Well I finished the installation today. Thank you everyone for you help. All in all it was pretty easy.
Here is a link to the product that I ordered. The web page sayd that it is for 2003-2007. Based on the connections I made there is not any reason that it would not work on any model.
http://www.troyfordaccessories.com/ProductDetails.asp?ProductCode=2W7Z%2D19A361%2DAA% 2DSUPERDUTY
If the installation instructions are not included here is a link to them
http://www.gemsen.com/Ford/Pdf/02-06_Gen_1_ITRM_Trucks_(8-29-05).pdf
The relays shown in the figure also are not included. They are ford part number YL3Z-19G390-AA. They are about $18 each from the dealership. I saw some online for about half of that but the ones from the dealership included the plug and wiring harness and I was not sure if the ones online did or not.
The only other thing to do was to find the correct wires and tie into them. The wiring harness that came with the system is also made for a security system so there were alot of unused wires. I disconnected these from the plug so that they would not be in the way. For the keyless entry system only a few connections were necessary. These were: Power, Ground, Door Lock, Door Unlock, Horn, Parking Light, and Dome Light.
Ground is an easy one. Power must be fused. The yellow wire under the dash (not the airbag wires) is a good place to fing this. The parking light wire was tied into on the back of the fuse box. The horn wire is on a connector against the bulk head that separates the the steering column and pedals from the heater controls and the radio. The dome light and lock and unlock wires are under the plastic cover around the hood release. As the wiring diagram in the installation instructions shows the lock and unlock wires had to be cut.
I guess that is about it. Any other question feel free to ask.
Old Jan 9, 2008 | 12:14 AM
hotrodracer's Avatar
hotrodracer
****OK, I ASK...****
But first: CONGRATS for working through the apparent maze of wires to completion!
When I bought my '05 F350 S.Duty I cheaped out and did not get the remote keylocks. Fortuneately for me my son drives tow trucks and has all the lock out tools, and knowledge to use them. Has done mine a couple of times which were free, except for a slightly red face here...
So I am about to order but I noticed a slight discrepancy between the part number on the picture you posted earlier, and the p/n on the internet Troy Ford parts site. Perhaps there is / has been a P/N update, but as long as the one you installed works, that number must be ok.
"IF" you or others has any input as to the P/N for my '05 F350 S.Duty, I are waiting, Si???
Old Jan 9, 2008 | 01:35 AM
cjcathey2002's Avatar
cjcathey2002
hey Darin
congrats on adding the module! so you are now able to buy the ford oem key fobs and use the ignition cycling sequence to program them?
Old Jan 9, 2008 | 09:14 AM
dc2842002's Avatar
dc2842002
As far as the Ford OEM key fobs I don''t know. The module came with to and that is all I need. To program them there is a little button on the wiring harness that you hold down for 15 sec then push the button on the key fob to program it. The module will support up to 8 fobs though.
Old Jan 9, 2008 | 12:27 PM
cjcathey2002
hey darin,
can you post a picture of the key fobs? i would like to follow your lead and put this on my truck. any idea if the door pads with the numbers would work with this system? sorry for the questions, i just dont want to put an aftermarket keyless entry on my truck. thanks.
Old Jan 9, 2008 | 12:31 PM
dc2842002's Avatar
dc2842002
Sorry for not getting back earlier somehow I didn't see you post this morning. I also noticed the difference in part number when I was trying to figure the wiring out. I don't know why it was different but everything worked
Old Jan 9, 2008 | 12:43 PM
dc2842002's Avatar
dc2842002
Here is the picture of the fob
I have no idea if the number pads will work or not
Old Apr 5, 2008 | 01:20 PM
cjcathey2002
hey darin,
just getting around to puttin in the keyless in my truck, what arrangement do you have the fuses in. i have mine in starting in the top row, empty, top, bottom, bottom, and then the only other one is the 5a in the bottom row. does this sound like the arrangement you have on your truck?
also did you just cut off all the extra wires from the harness....they are really annoying and manking a rats nest under my dash.
chris
Old Apr 5, 2008 | 01:26 PM
dc2842002's Avatar
dc2842002
I did the fuses exactly how the picture in the instructions showed.
As for the extra wires I didn't cut them off but I took them out of the connector. There is a slot that you can slide something thin into and release the wire. Cutting them off will be quicker than doing it the way I did it.
Curt's05
Apr 1, 2015 11:49 AM
fx4king2011
2009 - 2014 F150
Aug 30, 2014 09:21 AM
Curt's05
Jun 13, 2014 11:06 AM
philips
Apr 16, 2006 11:44 AM
mtcfish
2004 - 2008 F150
Feb 4, 2005 09:01 AM
