1978 - 1996 Big Bronco
How to replace rear window switch?
Old Dec 21, 2007 | 07:02 PM
Christy's Avatar
Christy
Question How to replace rear window switch?
I have a 94 full size Bronco. I want to replace the dash switch, instead of pay the dealer AGAIN to do it. Last one lasted only two years. It can't be that hard, can it? Please help and thank you so much!
Old Dec 22, 2007 | 10:17 AM
lostin90s's Avatar
lostin90s
Welcome to FTE .
Un hook battery
Pop out 2 trim strips remove 2 screw behind them.
Pull out light switch use flat driver in slot press towards **** it should come off.
Pull carefully along top as the retaining prongs break easy.
The surround comes out far enough to work on .Use short srcewdriver to remove 2 screws and replace switch.
But for ease of install turn key (emergency brake) And move shifter to 1st (to let surround come out )
Pop plugs off back of window switch and electric 4x4 (if have)
Should come right out.
Good luck PM me if problem
Old Dec 27, 2007 | 06:47 PM
Christy's Avatar
Christy
Replacing Rear Window Switch
Thanks "lostin90s". I will try it this weekend.
Christy
mytoolman
Mar 18, 2017 08:47 AM
candoo
May 19, 2016 11:45 AM
janschutz
Aug 26, 2015 03:05 PM
medicpg
1983 - 2012 Ranger & B-Series
Jun 28, 2007 01:01 PM
UF EMT FF
May 6, 2007 08:36 AM
