05 Cold Start Problem,
Old Dec 28, 2007 | 02:49 PM
Maxium4x4's Avatar
Maxium4x4
You could have a wire harness issue, what is the build date on the engine?
Old Dec 30, 2007 | 12:11 PM
Robyj's Avatar
Robyj
05 cold start problem
The engine number is 6EA58507, the manufacture date on the door is july 05, I hope this helps.
Old Dec 31, 2007 | 11:20 AM
Robyj's Avatar
Robyj
Hi Guys, on sunday (dec.30) my 06 had a hard time starting again and the fault light came on and stayed on, took it to dealer this morning (dec31). They said it was the alternator not charging properly and this was the problem for the cold sart issue, they put a new one in on warranty, i hope this cures it. Have a happy new year everybody.
Old Jan 1, 2008 | 02:37 PM
Robyj's Avatar
Robyj
well here we go again, about 6 hours after i took my truck home with new alternator installed it had a hard time starting again and the fault light came on and stayed,it was only -12C out. Will try another dealer for sure now as these guys don't seem to know anything more about my 6L powerstroke than i do.
Old Jan 1, 2008 | 03:51 PM
built tough's Avatar
built tough
my 2004 6.0L is doing the exsact same thing starts stalls starts stalls then when it does go runs like a tank and puffs the black out also its g2 the doctor on thursday maybe we will get somewhere. Probly something simple and will sound dumb but what is the fault light?
Old Jan 1, 2008 | 04:20 PM
Robyj's Avatar
Robyj
When the yellow engine light comes on it is relaying a code from the computer that lets the techs know what is going on, my truck does not puff white or black smoke when it does start and runs normal after.
Old Jan 1, 2008 | 09:15 PM
vatreefarmer's Avatar
vatreefarmer
I had a cold weather start last year. It would start, then die after running for about 3 seconds, and would repeat. Only happened when 20 degrees or colder. A change to synthetic 5W-40 solved the issue. Hope that helps
Old Jan 1, 2008 | 10:50 PM
Brian460's Avatar
Brian460
Two winters ago mine did the same thing with no codes. One dealer accused my wife of clearing the codes and refused to fix it. I eventually took it to another one and found 6 injectors that were not firing when the engine was cold, once warmed up the truck ran great.
Now this winter been kinda rough when starting and had it reflashed to heat the injectors coils before starting and seems to have smoothed it out. Check out youtube for some 6.0 cold starts.
Old Jan 1, 2008 | 11:17 PM
built tough
hope the link works http://www.youtube.com/watch?v=rkB5nfx9onY thats what are truck does only ares is a little rougher more like the second 1 http://www.youtube.com/watch?v=6ru7cdisUtY&NR=1
Old Jan 2, 2008 | 11:08 AM
Robyj's Avatar
Robyj
Took my 06 in this morningand they found the problem,one of the main fuses was losing power during startup, they have to replace the whole fuse box to fix it, thanks for the replys & tips guys. off to the bush in northern alberta for24 days. I think this is a great website and will be checking in when i get home.
Old Jan 2, 2008 | 03:02 PM
tvicker's Avatar
tvicker
Unhappy Exactly the same problem - in a WARM cimate
Hi all. I have an '04 6.0L and live on the Mississippi Gulf Coast. The coldest it gets here is about +28 degrees at night, and when it does it's big news. Last night was our coldest yet and when I went to start the truck it was about 35 degrees. Cranked for a LONG time with TONS of white smoke pouring out the tailpipe. I've had to hookup one of those emergency jump-start batteries just to get it started (after both batteries ran out of juice from cranking). This has happened to me many times recently. I have a new alternator (+/- 6 months), two new batteries (+/- 6 months), fresh 5W-40 Rotella T synthetic, just changed fuel filters and drained water two weeks ago (trying to solve this problem). I don't use a block heater because the daily average in January is 61 degrees. I bought this truck last December and did not have this problem last winter at all. I've had some hard starting problems also in recent weeks when it's quite warm (like 70 degrees) when I havent driven the truck for a couple of days. I'm an experienced technician with gas engines, but this is my first diesel so I'm hoping that I can soak in some knowledge here. Any ideas will be much appreciated. I'll call my local dealer and ask about it as well.
Old Jan 2, 2008 | 03:08 PM
fordextreme's Avatar
fordextreme
Did they happen to tell you what fuse they found was loosing power? Thats something I would like to check myself with a meter one morning when I think it will act up.
Wierd. wounder if it has anything to do with the glow plugs...
Old Jan 3, 2008 | 05:10 AM
  #28
Brian460's Avatar
Brian460
tvicker, if you can read the codes that would be a helpful start at 35 the truck should start no problem.
With my new flash my truck is back to normal it was -11F when I started mine at 4am this morning and it fired up and sounded great.
Old Jan 3, 2008 | 08:55 AM
  #29
Mark Oomkes's Avatar
Mark Oomkes
Every once in awhile my '04 cranks for awhile. I have no problem noticing the smoke when it is cranking or after it starts as it fills the cab to the point of not being able to see out the windshield. Great way to start off your morning, and we haven't been below 10* F yet this winter.
Old Jan 3, 2008 | 01:46 PM
  #30
Brian460's Avatar
Brian460
Sounds like you have an exhaust leak.
