Offroad & 4x4
welding DOM
Old Dec 27, 2007 | 02:26 AM
greythorn3's Avatar
greythorn3
Originally Posted by crazyredneckanyhow
WEll im planning on building either a set of radius arms or 4 linking the front of my 79 crew. I can get 1.75" OD DOM for 3.95 ft.
that will be sweat!! i use 220 arc welder for that stuff
Ray
Old Dec 27, 2007 | 06:24 AM
fishmanndotcom's Avatar
fishmanndotcom
geez has it gone up that much in a year?
-cutts-
Old Dec 27, 2007 | 07:34 AM
stryder's Avatar
stryder
Originally Posted by mustange70
try that again alot of pipeline is done with a 6010/7010 down hand stick, its quick and less prep is needed with that rod. I singled out mig for purpose of the metal transfer it uses in the arc makes its a pita for downhand, also mig is used in pipe roots downhande, but that is when you can actually roll the pipe, and you ususally hand a decent sized gap to work with too.
ooops...I forgot about pipe.
Old Dec 28, 2007 | 11:57 PM
Ryan50hrl's Avatar
Ryan50hrl
I'd say welding will be far too much work....just pick up an industrial sized tube of JB weld and glue them together......thats how toyota makes the new tailgates for their new tundras....so its gotta be good....plus then you don't have to worry about up or down....
Old Dec 29, 2007 | 07:46 AM
stryder's Avatar
stryder
I know your just trying to be funny, but this topic is one that could do without it.
Oh, by the way, a tailgate isnt structural, and there are industrial adheasives that are just as strong or stronger than the spot welds. In fact, most car manufactures have been using them for quite some time, so I dont see the need to single out Toyota.
Old Dec 29, 2007 | 08:39 AM
Ryan50hrl's Avatar
Ryan50hrl
Nothing wrong with a little humor here....i don't think anyones going to take serious the idea. And I do take issue with toyota specifically for this use as the tailgates are failing in spectacular fashion and they aren't doing anything about the failures, thus leaving consumers out to dry...
Old Dec 29, 2007 | 10:19 AM
greythorn3's Avatar
greythorn3
was that the quickset jbweld yoru using or the original? im starting to build my roll cage this weekend and need to pick up a couple tubes quick.. before the new years day run
Ray
Old Dec 29, 2007 | 10:28 AM
Ryan50hrl's Avatar
Ryan50hrl
quickset for sure....leaves plenty of time for drinking when your done....
Old Dec 29, 2007 | 10:35 AM
greythorn3's Avatar
greythorn3
that would be excellent for trail repair also! i hear its better then bailing wire!
Ray
Old Dec 29, 2007 | 10:40 AM
Ryan50hrl's Avatar
Ryan50hrl
better than bailing wire...but not as good as duct tape....
Old Dec 29, 2007 | 11:05 AM
greythorn3's Avatar
greythorn3
Now maybe if you commbined bailing wire with ductape for reinforcement it would be stronger then the jbweld, what do you think?
Ray
Old Dec 29, 2007 | 11:12 AM
Ryan50hrl's Avatar
Ryan50hrl
ooh..possible.....we should call nasa.....we might just be able to patch together those rickety space shuttles for another few years...
Old Dec 29, 2007 | 11:15 AM
  #28
greythorn3's Avatar
greythorn3
need some aluminum foil to make it look high tech to go over the duct tape and bailing wire.
ray
1973dieselhighboy
Offroad & 4x4
Oct 25, 2011 10:29 PM
Big_Dom
Sep 10, 2010 10:40 AM
Big_Dom
Feb 10, 2010 10:00 PM
bigjack
79
Feb 29, 2004 01:08 PM
bigdmizer
Feb 27, 2004 10:08 AM
