transverse leaf spring
got a question, is anyone out there running a transverse leaf spring. i have a few ideas going threw my head on how i am thinking of doing it, going to run the wisbone set up with a track bar. i am thinking of building the brackets off the frame and have a dom tube welded to the bracket for the spring to ride on or the other idea is to use a roller fairlead or turn some bearing bronze or something for the roller to ride on besides the plastic insurt. any ideas will help. thinking the roller cause it will have less resistance and be able to flex and move easier then the dom welded to the bracket for the spring to ride on. if anyone has some pics of there transverse set up that would be great to see some pics. going to be a winter project along with dove tail and bobed bed
yes only running one spring and it would be parralel with the axle, it is a simple set up has great flex and there is no limit to how far the axle can drop out and it will cost me about a hundred bucks in metal to build the whole suspension set up. running the wishbone link on the front with coils and it works great flexes ten times better then the 3 link i was running with the coils.
You had me thinking so I went to Pirate and searched myself.
This was the only thread I found with positive feedback on a suspension system like you are talking about. - this guy only ended up with 6" of up and 8" of down travel = very do-able with cage coils and extended radius arms. Paul (CaptainP4) probably has that much or more on his B-hoe and Im quite certain Fishy did also.
anyway, heres the link
M-151 Build Thread - Pirate4x4.Com Bulletin Board
All the other threads I found didnt have positive feedback from their results as I expected.
73, this is my third attempt at typing a long post so Im going to leave it at best of luck with the build and post pics.
This isnt a new idea. Its 150yr old technology that was left in the 70s before coilovers and link suspensions became popular.
will do i will get some pics of it now and when i finish it this comming spring with the transverse spring flexing will take some pics step by step thanks for the input but one question since know one is running this setup what is your opinion dome tube welded in place or a tube that will roll with the spring when flexing
thats what i was thinking was a roller and i cant see spending the thousands of dollars in the links and joints and all the other stuff needed when i have everything in the back yard for the transverse spring and i would rather put all that money in my tow rig building the motor. will get some pics together when i swap the suspension out and build it
been to busy wiring my garage so i can get my welder and all my metal tools out to my house and got to get my camper out of the garage so i can pull the ranger in and start on it. might be just after the first of the year before i can start on it but i will deffently get some pics up of it when i start
77hiboyboy
17
06-30-2008 02:46 PM
