still trouble starting
Old Dec 21, 2007 | 08:42 AM
2 stroke man's Avatar
2 stroke man
well, after alot of concideration, i dont think my start-up prob is my oil. talked to local injection shop, and lucas, and no one thinks my start-up prob is in running lucas, but i'm gonna change oil today and run no lucas and see what it does. it will crank crank crank then fire, and die if i dont hold throttle pressure to it, and keep it about 1000 rpms. i'm at a loss of ideas. gp's were replaces a cuple years ago. there are no codes thrown, and i changed cps. any ideas? only does it when its been setting over night and its pretty cold. someone said maybe injectors?
Old Dec 21, 2007 | 10:28 AM
fuelman's Avatar
fuelman
Sounds like maybe taking awhile to build pressure either hpop of fuel.Check fuel pressure during cranking.Maybe disconnect icp not sure if you did these in past posts.
Old Dec 21, 2007 | 11:25 AM
Action4478's Avatar
Action4478
It is oil related,, Most likely the LPOP...
What brand & weight of oil are you using?...
When it does die, is it harder to restart again?...
Old Dec 21, 2007 | 11:26 AM
tjbeggs's Avatar
tjbeggs
Have you tried it after plugging it in? I am still betting on oil though. Sounds like the cold weather Romps to me
Old Dec 21, 2007 | 03:49 PM
Neal 97 250's Avatar
Neal 97 250
My truck has been romping more lately. It sounds like that is typical in our trucks in the winter???
Old Dec 21, 2007 | 05:47 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Mine Did The Same Thing. I Let It Sit For A Week And Went To Start It And It Just Didnt Want To Go. I Pluged It In For A Couple Hrs And She Fired Right Up With Heat.
Old Dec 21, 2007 | 10:10 PM
2 stroke man
shell 15-40 diesel oil. 2 qts lucas. dont do it plugged up i dont think. it throws no codes, as previously stated. i just dont know. some times when i get on her real hard empty she is a lil hesitant, and has a couple soft spots, but i figured it was due to auto tranny. IDK
Dancingchicken
Feb 28, 2011 08:44 AM
2 stroke man
Dec 29, 2007 07:06 PM
97 HD
Jul 19, 2007 05:24 AM
351M
Oil & Lubrication
May 4, 2005 12:47 PM
Lone_Ranger01
1983 - 2012 Ranger & B-Series
Mar 6, 2005 07:37 PM
