temp. control unit problems.
Old Dec 19, 2007 | 09:50 PM
salesman112's Avatar
salesman112
i have an 05 lariat, my temp. control unit sometimes doesn't come on when truck is started. it has done it 4 times now over the last few months, unfortunately it will start working again before i can get home to troubleshoot the wires or make it to dealership, i have checked all the fuses/relays and none are blown or loose.
has anyone else out there had any problems like this with their unit?
Old Dec 20, 2007 | 01:30 AM
blackhat620's Avatar
blackhat620
The head unit of the Electronic Climate Control system is going bad. Take it to the dealer and let them replace it. It is covered under the 3/36k warranty.
Old Dec 20, 2007 | 07:50 PM
salesman112
unfortunately i have 72k miles, do you have any idea how much the head unit will cost?
Old Dec 20, 2007 | 09:39 PM
F250tuff's Avatar
F250tuff
I believe some other members have said it cost them about $500 at the dealership.
Old Dec 20, 2007 | 09:54 PM
blackhat620
salesman112,
You can get them from "Direct Ford Parts" (FTE sponsor) for $362.94
http://www.directfordparts.com/partl...05&catalogid=2
Old Dec 21, 2007 | 10:11 AM
69cj's Avatar
69cj
Try turning the headlights on and off when this happens. Others have reported that it will then start working. Just something to try that may save the money.
Old Dec 21, 2007 | 06:37 PM
RoyC's Avatar
RoyC
Mine does this also, only in cold weather (below 35f) and turning the headlights on after driving about two miles powers up the head. I suspect that we have a relay that is a little bit lazy and the added juice trips it. Mine has been doing this for two years now. Aside from it being a pest, I do not see it being worth $500 dollars to fix unless it finally dies.
RoyC
Old Dec 21, 2007 | 08:44 PM
salesman112
thanks for all the posts guys, i spent an hour last nightn on the net trying to find this part somewhere other than the dealer. and yes if the headlight trick works not worth the money.
Old Dec 22, 2007 | 10:19 AM
F250tuff's Avatar
F250tuff
Salesman112, Blackhat gave you a link that was "other than the dealer", and the price was much lower than the dealer.
Old Dec 23, 2007 | 08:21 PM
salesman112
f250stuff, i know but i was searching and in bed before he posted the link, and again i thank him for the help. i did find the part at the link for alot cheaper, but i am going to wait until it does it again and try the headlight trick. if that doesn't work i will break down and spend some of my money i was saving for upgrades.
kahoy
1978 - 1996 Big Bronco
Feb 6, 2024 05:02 AM
bigwiege
2004 - 2008 F150
Jan 31, 2011 07:07 PM
ech0sh4y
Jan 23, 2008 07:52 AM
ccecilm2
Nov 27, 2006 04:03 PM
Fr8hauler
Jan 25, 2004 05:18 AM
