1984 F150 Temp Control Unit
Old Nov 27, 2006 | 07:33 AM
ccecilm2's Avatar
ccecilm2
Does the in dash temperature control unit have a light in it? If it does, mine is burned out and is impossible to read at night. I have most everything pulled out of the dash waiting for a new blend/diverter door to come in and was just wondering if I need to pull out the temp control unit and replace a bulb before I put everything back together.
Old Nov 27, 2006 | 09:17 AM
fellro86's Avatar
fellro86
Yes, there is a bulb back in there, it should be lit up. I haven't had to do one, so can't give any tips, but I don't think it would be too bad, try reaching behind the dash to check things out before you tear it all apart. I would guess it to be the little #194 peanut bulbs like the marker lamps.
Old Nov 27, 2006 | 12:34 PM
Redneck1465's Avatar
Redneck1465
It really isnt that tough to do just take the dashpad off and then remove the gauge cluster and you can get right to it.
Old Nov 27, 2006 | 01:37 PM
ccecilm2's Avatar
ccecilm2
Thanks folks. It's parked outside and it's cold and raining now, will check it more closely for a bulb before I put the blend door back in and button everything back up.
Old Nov 27, 2006 | 04:03 PM
fellro86's Avatar
fellro86
Why would you need to take the dash pad or the cluster out? Take the two screws at the top of the bezel out that covers the radio and the climate controls, and then 4 screws on the climate controls, and you should have clear access to the back of the controls. (I just took a look at my 86)
The Masked Rider
Jul 29, 2013 05:11 AM
bluegrassfive
Sep 29, 2008 07:57 AM
jlalanas
2004 - 2008 F150
Jul 19, 2006 07:51 AM
