B-W 1356 problem?
Old Dec 19, 2007 | 08:56 PM
jk96kats's Avatar
jk96kats
B-W 1356 problem?
Hi, I have a 1990 f250 w/zf 5spd tranny and b-w 1356 t-case. I have no reverse in 2wd, just grinding when clutch is released, and some of my forward gears are starting to do the same thing. In 4wd hi and lo, I have no problems. I have replaced all clutch parts and transmission thinking that would fix it, but no luck! If anybody has had this problem or knows anything about it, your help is greatly appreciated. Thanks.
Old Dec 20, 2007 | 10:39 AM
subs1000w's Avatar
subs1000w
it could also be your r/p in the rear end since it only does it in 2wd while in 4x4 the front end moves the truck
Old Dec 20, 2007 | 08:42 PM
rebocardo's Avatar
rebocardo
I agree with subs!
Old Dec 23, 2007 | 12:32 PM
Quigoline's Avatar
Quigoline
Is that with the hubs locked??? Try it unlocked to cancel the front drive axle...If it moves, it is in the transfercase, not the rearend.....I rebuilt my 1356 and had to take it one step further than the new parts...my shift lever SHAFT PASSAGE IN THE CASE was oversized from ware and I had to make a bushing to get the internal gear selector to properly aline the internal gears..
Old Dec 29, 2007 | 11:20 AM
jk96kats's Avatar
jk96kats
thanks for the replies! i swapped the t-case and the problem is solved.
lisagoud
Nov 18, 2008 06:24 PM
lisagoud
1997 - 2003 F150
Nov 18, 2008 06:23 PM
lisagoud
Sep 11, 2006 05:36 AM
Argo
Jul 31, 2004 07:13 PM
adelyser
Jan 23, 2004 11:23 PM
