Carburetor issue
Old Dec 19, 2007 | 08:54 PM
jck_strw's Avatar
jck_strw
Carburetor issue
As I mentioned I'm quite the n00b here, so please excuse my ignorance. I will be happy to answer any and all computer related questions as payment.
I've posted 2 threads about some engine trouble:
https://www.ford-trucks.com/forums/6...ont-start.html
https://www.ford-trucks.com/forums/6...ng-a-stop.html
Perhaps my carburetor is the issue? Here's a pic:
One thing that troubles me is the red tube going nowhere. Is that typical? Second, the throttle plate is always wide open like that. Is that correct? I had my wife start up the truck and press the gas and it always stays open. Shouldn't that be opening/closing? I can close it manually (and then the truck stalls), but it always wants to stay open like that. Is that right?
Thanks.
1985 F150 6-cylinder 4WD
Old Dec 19, 2007 | 09:12 PM
moxy123's Avatar
moxy123
Post
That is not the throttle plate it is the choke. It should close as the engine temperature is cold for first starting.
Old Dec 19, 2007 | 10:08 PM
'85 SIX BANGER's Avatar
'85 SIX BANGER
That red hose should go to a fitting off the manifold, under the carb
Old Dec 19, 2007 | 10:31 PM
jck_strw's Avatar
jck_strw
Choke, gotcha.
What could not having that red hose connected cause? What kind of problem(s) will I see?
Old Dec 20, 2007 | 12:25 AM
Franklin2's Avatar
Franklin2
The choke probably won't work very well.
Old Dec 20, 2007 | 09:29 AM
5_labsownus's Avatar
5_labsownus
Look at this thread, it describes where the hose goes.
Rod
https://www.ford-trucks.com/forums/5...uum-lines.html
Old Dec 20, 2007 | 10:15 AM
jck_strw's Avatar
jck_strw
Dave-thanks. That makes sense.
Rod-thanks for that thread. Lots of good info there to digest.
Old Dec 21, 2007 | 06:43 PM
78ltd's Avatar
78ltd
Well now wait a minute. doesen't that red hose go to the air cleaner thermostat that has another hose running to the manifold like on the cars? Or not? (Guess I better get me a truck, huh?).
Old Dec 21, 2007 | 09:30 PM
woodbutcher05's Avatar
woodbutcher05
Outstanding.This thread answered the same questions for me.Thanks everybody.
Leo
Old Dec 21, 2007 | 11:41 PM
5_labsownus
this hose is part of the choke heater tube. It is the intake side and goes to the bottom of the manifold. The air cleaner thermostat gets vaccum from the intake.
Old Dec 22, 2007 | 08:43 AM
Franklin2's Avatar
Franklin2
Yes, if you look at the location of the red hose, it just goes to the air horn under the air cleaner. There is no vacuum in that area. It's just a clean air source for the choke system vacuum.
Old Dec 22, 2007 | 09:33 PM
jck_strw's Avatar
jck_strw
Ok, another dumb question. What type of carb is this? I just got the Chilton's for 65-86 Ford Pickups and I thought, reading previous threads, that this was a Carter YF 1-bbl carb. But looking at the pic (page 209 if you're following along at home) doesn't look like this at all. Checking the four carbs they diagram, it looks most like the YFA non-feedback, but even that doesn't look right. And that tube isn't shown on any of them. Is the Chilton lacking in this area? Am I maroon?
Thanks.
Old Dec 23, 2007 | 01:07 AM
78ltd's Avatar
78ltd
Oh, it's a Carter YFA allright. Identical in looks to the one on my 76 Maverick. Mine has the tube on it. Don't let looks deceive you.
Old Dec 23, 2007 | 09:36 AM
5_labsownus
It's a carter YF. There are few minor changes/variation over the years but they are all the same. I personaly note 1 change in your picture. On my truck the OEM carb and both rebuilds have the choke vacuum tube inlet on the other side.
1 bebuild had a larger fuel bowl and the other was the same as the OEM.
Old Dec 23, 2007 | 10:24 AM
woodbutcher05
Something to remember.The Carter(R)"Y" series had MANY versions.When buying or swapping for another,be sure to check carefully that you are getting the version that you want.
Also,you will find that the mounting holes have different spacing.Earlier are CLOSER together than the feedback junk.However,IIRC you CAN mix and match the carb lower end to get the correct spacing for the mount holes,and still get away from the feedback junk.
Leo
