Rough running when approaching a stop
Old Dec 18, 2007 | 06:30 PM
jck_strw's Avatar
jck_strw
Hi
'85 F150 6cyclinder 4WD
(where do you configure your signature, so I don't have to type this everytime? I looked in the User CP, but I must be missing it)
The truck starts up fine, every time. Driving, the truck feels smooth. Sometimes, when I'm approaching a stop sign, red light, etc. the engine gets real rough. Like it's going to stall. But it's only when I'm slowing down to stop. When I actually stop, the engine is smooth again. What could be the issue(s)?
Thanks.
Jim
Old Dec 18, 2007 | 09:49 PM
jck_strw's Avatar
jck_strw
Ah...25 posts are needed.
Old Dec 18, 2007 | 10:08 PM
Holmesuser01's Avatar
Holmesuser01
Transmission? AOD? Idle set too low? Cant begin to guess.
Old Dec 18, 2007 | 10:28 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The Carter YF 1BBL carb is famous for the baseplate to carb body screws working their way loose. Since most of the later versions also have the air cleaner that bolts to the engine, it tends to hold everything in place rather well, most of the time.
Give the carb body a quick test wiggle. You just may find you have a few (4) loose screws, no pun intended..........
Old Dec 18, 2007 | 10:36 PM
Rogue_Wulff
More to it than that. I still don't have any way to add a sig. Sucks, cause that sure beats having to list the details everytime.
Old Dec 19, 2007 | 10:20 AM
bob_351's Avatar
bob_351
I had the same problem turned out to be a vacumn leak, mine was at the base of the carb there was a crack. Check the carb bolts as suggested but also vacumn lines and maby spray some carb cleaner around the manifold to see if there are any leaks there. If there are any leaks the engine will rev up. Just do a search on vacumn leaks and you can get some more suggestions
Old Dec 19, 2007 | 10:54 AM
jck_strw's Avatar
jck_strw
Cool. Thanks for the suggestions. This is my first "automotive adventure" where I'm hoping to fix the things that aren't working, rather than take it to a mechanic. I imagine there will be lots of rough patches along the way, but you'll never learn if you don't try.
Already made my first fix! The bench seat had a big ol' tear, so I grabbed my duct tape and patched that sucker up.
Old Dec 19, 2007 | 02:57 PM
Rogue_Wulff
Also, don't forget to check the brake booster for vacuum leaking. If you hear a whistle sound while you have the brake pedal pressed, it's bad.
Old Dec 20, 2007 | 03:56 PM
biga17133's Avatar
biga17133
All Very good advise,, but i love the part "GOT DUCT TAPE" lmao.....
Old Dec 20, 2007 | 05:31 PM
jck_strw's Avatar
jck_strw
If you can't duct it...
Old Dec 23, 2007 | 06:24 PM
FESuperDuty's Avatar
FESuperDuty
This duct tape thing; you don't work at a sawmill in south Missouri do you? LOL
Old Dec 24, 2007 | 11:19 AM
jck_strw's Avatar
jck_strw
My fellow duct tape disciples are all over the world. It's what holds the world together, I hear.
