1978 - 1996 Big Bronco
Rear Diff swap
Old Jan 3, 2008 | 09:10 AM
  #31
N8BIG's Avatar
N8BIG
I've got a 9" with a sensor ring welded to my full spool!! it works but there is times I wish I had a Sterling!!!
1995 Bronco on 40" Hawgs!
Old Jan 3, 2008 | 10:48 AM
  #32
rlh's Avatar
rlh
Originally Posted by bossind
I see, it eleminates the C clips. Doesn't really give him sronger axles though, and he would still have the 8.8 housing. The problem with the 8.8 housing is the tubes spin/break loss from the casting.
Well, he was talking about running 36" tires. While it wouldn't be as bad a corp 14 bolt, I don't like the ground clearance of the sterling unless the tires are 38" or larger. The best option for 38 and under in my opinion is the D60 set up with a tone ring. However, I actually have a Currie housing with thicker chromolloy tubes. I had the axle built with some of their parts and some of my parts when I lived 55 miles down the road from them. Had the Eaton eLocker for the D60 been out when I had this axle built, I would have gone that route. I wouldn't have bother with the tone ring on the D60 because I have a'90. I was planning on getting another bronco so I put the tone ring in case I got a 92-96. I ended up with an '86 and '81 and both have the 9".
Old Jan 3, 2008 | 10:50 AM
  #33
rlh's Avatar
rlh
12000lb Hydralic Milemarker.
Do you think an electric winch would fit in there?
Old Jan 3, 2008 | 10:59 AM
  #34
bossind's Avatar
bossind
Sure it would.
Old Jan 3, 2008 | 05:48 PM
  #35
89F1fiddy's Avatar
89F1fiddy
I agree with the weak housing as my 8.8 is seaping diff fluid at the spot welds where the tubes go into the housing.I have been wheeling my truck for 3yrs and it has open diffs.Fortunately mine is an 89 so it is getting a good old 9" in the spring. I will lose the rabs which hasn't worked since I started wheeling it. Good luck with axle upgrades.
Old Jan 3, 2008 | 09:01 PM
  #36
96Bronco1's Avatar
96Bronco1
I checked out the Winch set up, that is sweet. You should make a kit and market it! Nice.
Old Jan 3, 2008 | 09:52 PM
  #37
bossind's Avatar
bossind
Thanks, heres a whole list of builds on the old bronco from hydroboost install to exhaust mods. Just finished the Rust Buller and Herculiner tonight to the front floot section.
http://www.4x4preservation.com/forum...splay.php?f=23
Old Jan 4, 2008 | 12:03 AM
  #38
17fordguy's Avatar
17fordguy
the booster mod is cool might do that on my f150 how hard is it
Old Jan 4, 2008 | 08:15 AM
  #39
Kemicalburns's Avatar
Kemicalburns
bossind is the man, ive been asking him to market that winch plate for some time. see you on fsb Bossind
Old Jan 4, 2008 | 10:37 AM
  #40
bossind's Avatar
bossind
Wasn't hard at all, took some time to figure out what fittings I needed and where to find them - you don't have to worry about that.
Old Jan 4, 2008 | 05:51 PM
  #41
96Bronco1's Avatar
96Bronco1
Thumbs up
[QUOTE=bossind]Thanks, heres a whole list of builds on the old bronco from hydroboost install to exhaust mods. Just finished the Rust Buller and Herculiner tonight to the front floot section.
http://www.4x4preservation.com/forums/forumdisplay.php?f=23[/QUOTE]
That is some REALLY NICE WORK!!! Checked'em all out, thanks. Man things really get rusty up there. Down here in New Mexico all we have is dust, hose it off and you're good to go. Guess I'm lucky, no cancer. What kit and axle did you use for the front swap?
Old Jan 5, 2008 | 11:09 PM
  #42
bossind's Avatar
bossind
Rust sucks, I'm starting to win the fight over it though. I used Cage Radius Arms and an axle from a 77 F150, the rest I built.
Old Jan 6, 2008 | 06:24 PM
  #43
helirich's Avatar
helirich
Actually, The housing is no stronger on the 9". If you are haveing problums, you need an axle truss. The problum with 8.8's is:
1. The wheel bearings ride on the axle.
2. C-clips
3. The diff carrier bearings are not supported enough and let the ring gear deflect.
C-clip eliminaters are no good for Broncos because the bearings are not designed for high axial (side) loads. Their fine for drag racing. The only way to get rid of them on the bronco is with a full float conversion. It also gets the wheel bearings off the axle. (In fact, it takes all axial and radial loads off the axle.)
The diff carrier bearings can be stiffend with an after market housing cover that has braces built in.
It might intreast you to know that the 9" has smaller diameter axles than the 8.8
tom197037
2004 - 2008 F150
May 17, 2010 06:59 PM
C Holmes
22
Apr 9, 2008 07:21 AM
alwaysmessedup
Jun 23, 2003 11:36 PM
jberylecrider
Jul 31, 2002 05:05 PM
