So I changed my coolant filter...
Old Dec 18, 2007 | 12:05 PM
riggz's Avatar
riggz
Exclamation So I changed my coolant filter...
Here's the results of my coolant filter. Granted there was probably some residual left from my old engine (2k miles) but this is probably mostly from the new block that was installed recently. You be the judge if this mod is worth it.
Old Dec 18, 2007 | 12:13 PM
Joshua0606's Avatar
Joshua0606
What kind of filter kit are you using?
Old Dec 18, 2007 | 12:17 PM
riggz's Avatar
riggz
Just the standard non charged filter offered by DieselSite.com
Old Dec 18, 2007 | 04:07 PM
Kep4's Avatar
Kep4
Jäger
It's nice to have that junk filtered out instead of clogging the oil cooler!
Thanks for the pics, very nice.
Old Dec 18, 2007 | 04:20 PM
TMartinLVNV's Avatar
TMartinLVNV
I just installed the same filter kit. Very easy to do. How many miles total did you have on that filter? I bought some extra filters when I ordered the kit. When those run out, do you think that an oil filter from a local store will work, or should I always get the same ones from dieselsite?
Old Dec 18, 2007 | 05:33 PM
riggz's Avatar
riggz
I'd continue to use the same filters so you don't run into any issues. I had about 6-7k miles on it including both engines.
Old Dec 18, 2007 | 06:34 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
And shortly after that goes the EGR cooler. Nice pics Riggz. As they say, a picture is worth a 1000 words.
Old Dec 18, 2007 | 06:46 PM
johnny567's Avatar
johnny567
Do these filters affect your warranty? Id like to get one but you know how they like to try & weasle out of warranty claims.
Old Dec 18, 2007 | 07:58 PM
Kep4's Avatar
Kep4
Jäger
I seriously doubt a coolant filter would affect warranty. The Dieselsite coolant filter setup is a bypass filter. If it gets clogged the coolant system still works as designed by Ford with no adverse affect on anything.
The major benefit is a clean cooling system, clean oil cooler passages, and probably a longer lasting water pump. As PS_wannabe stated, once the oil cooler clogs the EGR cooler will likely fail shortly thereafter. That's an expensive repair after 100K. The coolant filter prevents this from happening. It's relatively cheap insurance.
Old Dec 18, 2007 | 08:12 PM
Maxium4x4's Avatar
Maxium4x4
If this filter removing the junk voids my warrenty, I'll take the chance...
My filter....Click Here
Old Dec 18, 2007 | 08:13 PM
riggz's Avatar
riggz
I doubt any dealership would deny your warranty because of it. If they do, you wouldn't want them servicing your truck anyway.
Old Dec 19, 2007 | 06:44 AM
bismic's Avatar
bismic
My dealership saw it and asked what it was - but they said "no problems w/ the warrantee". They are typically pretty quick to void warrantees on other issues. I would say that not many (if any) dealerships would give you a hard time about it.
Old Dec 19, 2007 | 11:12 AM
BowTieHatr's Avatar
BowTieHatr
guys, im not saying a coolant filter is a bad or good idea. but the coolant filter only gets out what is floating in the system. the oil cooler and egr cooler are fed through ports in the block, so if anything (scale or casting sand etc.) is in the block, it is going straight to the oil cooler. yes the filter may help, but it will only get the small stuff.
Old Dec 19, 2007 | 11:30 AM
OZX1's Avatar
OZX1
Good insight! With that information in mind, I think I did good I installed by coolant filteration system about 50 miles after my EGR and oil coolers were replaced.
Old Dec 19, 2007 | 11:34 AM
OZX1's Avatar
OZX1
Unhappy
Hey, Brian-
I dunno why, but I can't see the pics! Can you post them in your gallery?
Thanks-
Brian
