So I changed my coolant filter...
Old Dec 19, 2007 | 11:35 AM
loubell's Avatar
loubell
so if anything (scale or casting sand etc.) is in the block, it is going straight to the oil cooler.
So in order to test your theory, we would need to see two 6.0 oil coolers of similar milage. One with a coolant filter, and one without. This way, we could all see if the coolant filters are truley making a difference, or if they both have the same junk in them.
Old Dec 19, 2007 | 12:00 PM
4x4Mark's Avatar
4x4Mark
Take any 6.0L with 60k+, that is not running a coolant filter, dip your finger deep into the coolant reservoir, and you'll know the difference. At 70K mine is still crystal clear and prestine. My brother's on the other hand, with similar mileage, has already gone through the EGR cooler twice and his reservoir resembles a mud bath.
Mark
Old Dec 19, 2007 | 09:04 PM
riggz's Avatar
riggz
Originally Posted by ozx3+1
Hey, Brian-
I dunno why, but I can't see the pics! Can you post them in your gallery?
Thanks-
Brian
<TABLE><TBODY><TR><TD vAlign=top width="100%">Are you attempting to view them at work? They may be filtered. I'll send you a PM with links to them.
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --></TR></TBODY></TABLE>
Old Dec 19, 2007 | 10:59 PM
A. Michael Foxtrot's Avatar
A. Michael Foxtrot
How much of a pain is it to install the bypass? I didn't see a write-up in the tech folder.
Old Dec 19, 2007 | 11:28 PM
WilliesSD250's Avatar
WilliesSD250
Foxtrot, go to dieselsite.com and look under the link to coolants and additives. It''l lead you to their coolant filtration systems. Also if you do a search in this forum, you should find loads of info on coolant filtration system installs
Old Dec 19, 2007 | 11:32 PM
riggz's Avatar
riggz
It's not hard at all. The kit comes with instructions and everything you will need to install it (minus something to cut the hoses and a ratchet and socket set).
Old Dec 20, 2007 | 06:54 AM
OZX1's Avatar
OZX1
No pain at all for me. I took less than 1/2 a beer to do it!
Old Dec 20, 2007 | 10:43 AM
A. Michael Foxtrot
Thanks, I'll do some more snooping around.
Old Dec 20, 2007 | 11:59 AM
Kep4's Avatar
Kep4
Jäger
Here's a link to Dieselsite AMF: www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=324
It's a very easy install with great benefits. They also offer a filtration setup for the TorqShift which is effective and easy to install.
Old Dec 20, 2007 | 06:20 PM
A. Michael Foxtrot
Thank you good sir.
riggz
Jul 13, 2013 08:49 AM
riggz
24
May 5, 2010 02:00 PM
HarleyFXDL
Feb 6, 2009 05:04 PM
riggz
Nov 11, 2008 04:29 PM
riggz
Oct 1, 2007 08:01 PM
