Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
air compressor question
Old Dec 17, 2007 | 09:35 PM
Robert R's Avatar
Robert R
I have a IR 80 gallon 7.5hp 24cfm 175psi air compressor.
I have 1/2" pipe coming from the tank going to a regulator with 1/4" fittings
and 100' of 3/8"hose with 1/4" fittings going outside where I do most of my work.
When I use my impact wrench it don't have the power it should have.
I use it were I work and it works fine.
I can also use shorter hose and still no power.
Thanks for your help
Old Dec 17, 2007 | 10:01 PM
Nitramjr's Avatar
Nitramjr
Are you sure your pressure gauge is right? Maybe you aren't giving it the pressure you think you are.
I can't imagine the 1/4" fittings are robbing you that badly in just 100'. Try turning up the regulator.
Old Dec 17, 2007 | 10:19 PM
Robert R's Avatar
Robert R
Thanks for the reply my regulator only shows 100 psi max setting
and that is what i have it set on.
my compressor says it should put out 175 psi
I thought the size or diameter of hose might be the problem
Old Dec 17, 2007 | 11:02 PM
Ford_Six's Avatar
Ford_Six
The hose is pretty standard, I would take the regulator out of the circuit and see if that helps.
Old Dec 17, 2007 | 11:34 PM
Robert R's Avatar
Robert R
I will try that tomorrow thanks.
this has been a problem sense i bought it
Old Dec 18, 2007 | 12:28 AM
fixnair's Avatar
fixnair
If you can, put a pressure gauge right at your tool. Read the pressure as you use the tool. I'll bet your pressure at the tool drops down to 75 PSIG. Ford6 has probably hit the nail on the head with his suggestion to remove the regulator. Another notorious restriction is cheap Chinese quick connectors. they do not have a large enough orfice to pass enough air to keep up with your tool. Also, hoses can develop an internal flap that will close the hose off during high flow conditions.
Good luck with it
Old Dec 18, 2007 | 01:14 AM
Mr Jimi's Avatar
Mr Jimi
Thumbs up
It's your 100 feet of hose and 1/4 inch fittings robbing your volume and anywhere else you have 1/4 fittings.
Having 3/8 hose is a good thing but not if you use 1/4 fittings, it's almost same as using 1/4 hose. And the 100 feet of lenght is reducing your volume also with restriction.
Go to your local fitting supplier and get some larger fittings and you will see and feel a big difference
Take a look at this site
http://www.gates.com/index.cfm?locat...tsFluidAirFlow
that should help ya
Jim
Old Dec 18, 2007 | 06:04 AM
wizzard351's Avatar
wizzard351
i use a 7/8 inch hose for getin out of the shop(50ft)and big fitting (1/2in) no problems also turned up the psi to 160 got enuff power that if your no carefull it twist off lugstuds
Old Dec 18, 2007 | 07:24 AM
GlennFordx4's Avatar
GlennFordx4
I run a 100' 3/8 hose with 3/8 fitting at the compressor end and miton 1/4 fittings at tool end without a regulator on my snap on IM650 impact and it works great even at a 100 psi,so I to think it is your regulator robbing you of air flow.
Myself I built a small regulator with 1/4" fittings and a gauge and put it on right on the tool if I need to regulate the air pressure and the only thing I think I use that needs it is my nail/staple guns.
Old Dec 18, 2007 | 04:07 PM
Robert R's Avatar
Robert R
Thumbs up
Thanks for the replies Ford six was right it was the regulator.
I took it out and ran my impact it works grest now.
I guess I will have to buy a better regulator that will go up to 200 psi.
thanks for the help
Old Dec 19, 2007 | 12:10 AM
fixnair's Avatar
fixnair
I don't think you will find one that regulates beyond 125 PSIG. But you can solve your problem by installing a larger regulator. 1/2" should provide you with plenty of air.
Old Dec 19, 2007 | 08:14 PM
Robert R's Avatar
Robert R
Thanks I will try that
rpatrick
Garage & Workshop
13
Nov 13, 2007 05:58 PM
rednekf350
Garage & Workshop
Apr 2, 2006 02:48 PM
oldcoupe42
Garage & Workshop
25
Dec 5, 2005 10:42 AM
hoxiii
Offroad & 4x4
Jul 17, 2004 09:45 PM
rebocardo
Garage & Workshop
Feb 9, 2004 12:50 AM
