Sponsored by: Auxito
stuck tow hitch in receiver
Old Dec 16, 2007 | 10:36 PM
SnowHiker's Avatar
SnowHiker
any of you guys experienced this? i cant get the hitch off. its like rusted in. i was thinking of putting some kind of release lube- squirt it in while i park on a steep hill. let it sit and tie my tow strap around an oak tree and try pulling it free. what would you do? thanks
Old Dec 16, 2007 | 10:50 PM
LxMan1's Avatar
LxMan1
Sounds like a plan to me. I had one freeze in mine once after it rained and got below freezing. ut, if it won't come out, nobody can steal it
Old Dec 16, 2007 | 11:14 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I've had to do that a few times. Just hook a chain to the hitch, and something sturdy and give it a tug.
Old Dec 16, 2007 | 11:22 PM
Mr Jimi's Avatar
Mr Jimi
Chains or ropes will only bind it and make it worse..
Get a can of PB blaster, soak all of the inside of it pretty good.
Have a cold adult beverage and gently tap it on all sides and you will hear a different sound and it will begin to come out and repeat as necessary and when your done have another cold adult beverage
Take your time an all it needs is some light taps and when you get it out, I will let you pass me a cold one
Jim
Old Dec 16, 2007 | 11:29 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Bah...just make sure the chain/rope is hooked to the tree (or whatever) completely horizontal to the hitch (not above or below the hitch). It will pop right out.
PS: Don't forget to remove the pin
Old Dec 16, 2007 | 11:50 PM
SnowHiker's Avatar
SnowHiker
haha you guys are funny,, ill let u know how it goes,, tx!!
Old Dec 17, 2007 | 12:15 AM
shawntxt's Avatar
shawntxt
wd 40 works every time
LastSplash's Avatar
LastSplash
Spray the hell out of it with wd-40 and let it sit for a while, then smack it with a sledge hammer if you dont have a heavy hammer another way is to back up to a light pole that has a concrete base (they are easily found in most large parking lots). I just backed up until the hitch touched the pole then pulled forward about an inch or two put the truck in reverse and let it idle back.
Old Dec 17, 2007 | 01:11 AM
67blueford's Avatar
67blueford
just leave it in ... its a good way to keep small cars off ur butt on the road unless they have a good deal on a radiator
Old Dec 17, 2007 | 01:30 AM
LastSplash's Avatar
LastSplash
I used to think that until I was out testing my 4WD and as I was traversing a small ditch my truck came to an abrupt halt as the hitch comenced to plant itself 3" deep into the dirt leaving the axle just high enough that it couldnt be reached with a jack. So from now on I keep it under the back seat.
Old Dec 17, 2007 | 04:25 AM
Bobby82490's Avatar
Bobby82490
I would just hook a strap(not chain) and yank it out, and maybe heat it up a little with a torch. If you get it out make sure you take precautions so that it dont happen again. Every oil change, maybe while the oil is draining, pull the hitch out and oil/grease it. I do this and never have problems, but if you go through alot of high water you might want to do it more often.
Old Dec 17, 2007 | 04:44 AM
alchymist's Avatar
alchymist
"Mifflin Clay"
Hammer on it if you want, but don't heat it. A lot of that stuff is heat treated...........Sometimes if you give it a couple light whacks IN (with the pin out), it will loosen it enough you can work it out. The oil helps.
Old Dec 17, 2007 | 05:32 AM
LastSplash's Avatar
LastSplash
Another way to break them free is to put an impact wrench on the nut on the bottom of the ball and pull on the ball at the same time.
Old Dec 19, 2007 | 06:44 PM
tofer76's Avatar
tofer76
Mine Did that once i put chain on it and around a tree tugged abit then left the truck in drive (big block bout 6 inched in front of the wheels so it wont run away) then smacked up down left right repeatedly til it came out afterards clean the reciever out with a flat scraping tool and wire brush the draw bar down good keep draw bar out when not in use and get a cover for reciever hole no prob since
Billyclub
2009 - 2014 F150
64
Nov 2, 2017 12:15 PM
brentkhack
Jul 16, 2014 12:11 PM
VQT
Jun 18, 2012 11:07 PM
Onus
All Things Towing
Nov 3, 2010 06:55 PM
Agapemou
Jun 27, 2003 01:18 PM
