bizzare ignition problem?
Old Dec 15, 2007 | 03:46 PM
MintFord's Avatar
MintFord
I've let my '77 F250 sit for a few weeks due to a bad wheel cylinder (too lazy to take the hub off and replace). I went to fire it up today and it just cranked and cranked, not even trying to start. All I had at the time was a test light, so I checked to make sure there was power and ground pulse to the ignition coil first, since its easy. When I left the key on, I heard a clicking from inside the distributor cap, and found that the ground wire to the coil was pulsing during KOEO. I unplugged the coil wire from the dist. and coil was firing without the engine running. I immagine that its not supposed to do this. I would think it should try to start if its got any spark at all. I didn't smell any fuel in the carb and was going to go get some ether but it started raining. I know the last time it ran out of gas i had to crank it forever to make it start. Anyway, my main question is, has anyone seen a coil fire like this without the engine running? I'm guessing bad ignition conrtol box? Its a former 400 truck now with a 360.
Old Dec 15, 2007 | 04:18 PM
Mil1ion's Avatar
Mil1ion
Bad pick up module in the distributor ?
That's the component that fires the pulsing signal.
Is the distributor shaft actually turning when engine is cranking ?
Old Dec 17, 2007 | 06:00 PM
rusty7983's Avatar
rusty7983
is it getting fuel? my trucks do the have a hard time starting if they sit for a few weeks. pour a cup of fuel down the carb and try to start, see if that works. it will prime the fuel system, as these trucks don't do it well themselves.
Broncojunkie
19
Dec 19, 2014 07:53 PM
bobaloo11
50
Aug 6, 2009 02:15 AM
Norm Spaulding
15
Mar 10, 2008 07:23 PM
mb43
Sep 21, 2004 12:14 PM
red4691
1983 - 2012 Ranger & B-Series
Nov 2, 2003 07:11 PM
