Still Dead
It cranks strong and I have plenty of compression. Sometimes, while cranking, it seems like it's going to start but then goes back to just cranking only when the manual choke is on full.
The plugs look dry after trying the above, but I can see gas puddling in the intake and there's a strong gasoline odor. A small amount of gas seem to be wetting the side of the carb. I checked for stuck, sunk float also.
I've checked all wires.. resistor wire, grounds, coil and checked for pulse light on -neg. side of coil while cranking.
It ran, was shut off and never started again.
Basically, should I have a blue spark or is yellow ok?
Does it sound like a carb problem? I have one on order, but I can send it back.
Tomorrow I'm going to check the three vacume lines... for the third time.
Any help will be appreciated.
There is not enough information to justify replacing the carburetor at this point. While a breaker-points ignition system will have less spark energy than its modern counter parts, yellow spark is not OK. Let's start a series of tests, after you correct the fuel leak.
Try this test. Pull the distributor cap off, and make sure that the points are closed. If not, you can turn the motor over until they are. Turn the key to RUN, and measure the voltage from the BATT post of the coil down to ground. Use clean, unpainted metal on the engine block for ground. Report your results. A '73 would have push-style boot connectors on the coil, but there should be a nut exposed at the base that you can get your meter probe on. If not, you can scoot the wire boot a little off the coil terminal to get at some metal; just make sure the coil is still connected for this test.
It is unclear to me what you have done to check the wiring as you described, but suffice to say that visual inspection of wiring will tell you very little. A multimeter is absolutely necessary.
Closed points to ground = 12v. Neg side of coil to ground = 12v.
I have been using an analog meter, but if you prefer I can use my Fluke digital for more exact measurements. I like my analog meter better, though.
If you need any other measurements, just request them. I have measured the voltage, resistance and continuity of many, many of the wires and connections over the last 3 days and haven't found a problem with any.
I ran a direct wire from the battery to + side of coil for a few seconds and still got yellow spark at the coil. (Plug wire attached to coil wire).
Trace the following wires and check continuity:
1. Negative terminal of the coil to the points, through the distributor housing.
2. There should be a small jumper wire inside the distributor between the stationary base-plate and the rotating breaker-plate. This wire is responsible for grounding the coil when the points are shut.
With the points closed and key in run, the batt terminal of coil to ground is 5.95v. From the negative terminal of the coil to ground is -.01v (apparently I originally measured while points were open).
As for continuity. Neg terminal of the coil to the points = 0 ohms
The small black jumper wire also has 0 ohms resistance from end to end and to all other parts of points and plate etc.
I did not see any rotating plate in the distributor. The only thing rotating is the distributor shaft with point cam. I checked continuity to every wire and part I could see to one another and to block and there was 0 ohms to all.
Last I checked one other item, but I don't know if it is of revelence. Points open to ground was 73 ohms.
I hope these measurements help.
Thanks!
And when you say it ran and was shut off. Do mean, you tried to start it recently or it sat for several years in storage?
Josh
I have also done the same with the wire attached to the terminal on the cap and the plug grounded to the block.
When I say it was running... it was less than a week ago. It was raining if that makes a difference. It was shut off about an hour or so and never started again.
Just a few minutes ago I discovered a not so good vacume line going to the brake booster. Plugged it at the manifold and attempted to start it. Just cranked, that's it. After about 5 seconds of cranking I stopped and gas spit up out of the carb as usual.
That's it.
I assume it's dry inside the cap? It doesn't take much moisture to mess with things.
The rotor looks decent and tang is up and springy?
What are the ohms for the spark plug wires? The standard is usually 8000 ohms per foot.
Josh
The gas spitting out of the carb.
The carb is a Carter YF 6376 1bbl. I felt that the gas spitting from the carb was unusual, that is why I ordered a rebuilt one (not received yet)... It really dumps fuel. I didn't seem to bother with that right now because I still need a good spark. But we can talk carbs too. My truck is a step van so I can remove the doghouse and air filter and watch while cranking it. I pull the manual choke, closes the choke plate, cracks open the throttle and gives a small squirt of gas from the acc. pump. Then I crank the motor for maybe 5 seconds (without touching the acc. pedal). During and especially when I stop I can see a mist/droplets of fuel coming out. It can be seen ON TOP of the choke plate by now. I open the choke and the plate is soaked with gas and there is a puddle down in the manifold. It does it without the choke on too. But if I floor the gas while cranking, it doesn't seem to do it. Day before last I pulled the carb. I removed the top to see if my float sank causing fuel to dump but it floats and I cant hear anything spashing around inside. So I assumed it isn't my float. It looked fairly clean so I hosed it with some carb cleaner and reinstalled it.
I DID notice something that I thought was odd, but it looks like it was made this way. The fuel nozzle located in the venturi has an orfice on the top as well as bottom. Thats all I can say about that.
I have cranked the motor, choke off, while looking inside with a flash lite and see there is quite alot of fuel (Many steady drops) coming from this venturi nozzel. Top and/or bottom of it.
So that's the scoop, sorry to be so long, but I wanted to be as detailed as possible.
Tomorrow I get to work on my son's '73 VW bus... but that's a different forum.
You seem mechanically inclined, a carb kit to rebuild what you have would have been a better choice than getting a reman carb with a sketchy history.
Either way, I would tend to think that if the van was left to sit for a period of time and you go to start the engine, it should at least run for a bit before the carb floods out.
Way back in the day with a 360 and an Motorcraft 2100 2 barrel, the only way to get the stupid thing to start was to hold the throttle wide open until the engine caught. That engine was quickly replaced with a mild 390 and Carter AFB, but like I said it was pretty much the only way to get it to start unless I had just shut the engine off for only a few minutes.
Josh
Josh
Occaisionally it will sputter while cranking, but it never starts, but only with the choke on full. If the choke is off and the pedal to the floor, it won't even sputter. I have tried variations of choke-throttle settings and nothing.
But with that much fuel and weak spark, I don't see it starting.
