NB needs no spark help 87 2.9L
Old Nov 2, 2003 | 05:37 PM
red4691's Avatar
red4691
As I've found at any auto enthusiast forums to be this Ford forum is great! I've searched and found some things to try but nothing that pertains exactly to my fathers problem. So I'm looking for some help to keep us from spending a lot of $ at a dealer getting his truck fixed.
A tiny history, first off I'm a GM guy, I know boo hiss, but this is my dad's truck and all he's ever owned is Fords so help him if not me He's in his 70's, limited income so I'm the mechanic, wouldn't be a problem if it was a GM, I all ready know all the crappy stuff that's wrong with them
Anyway, 87 Ranger, 2.9L, Just quit in the driveway while running. No spark at the coil, I will check to see if there is pulseing at the neg side tomorrow (found that in my search) with a test light, there is a smell of gas while cranking so I figure the injectors are firing. I've seen things in my search about codes, is there an easy way to check codes without a scanner? With old GM's we go the paperclip, flashing light method, is something like this possible with a Ford of this age?
I used a DVM on the coil and I have 12V on the hot side and 12V on the low side which drops to 9 while cranking, I figure that it is pulsing just that the meter isn't fast enough to show it. If it is pulsing is it still possible that the coil is bad? It's like really rusty, does it depend upon the frame of the coil for a good ground?
The wireing in general looks really good for the age of the truck, no cracks, seals are good, no crud on the contacts.
Any suggestions you can give to an old GM guy to help an older Ford guy would be greatly appreciated, thanks in advance!
Lance
Old Nov 2, 2003 | 06:19 PM
Dealford's Avatar
Dealford
Pulling codes on your dads' truck can be done with a VOM. Isn't that truck equiped with the EEC-IV system? If so, you'll find the proceedures in the Tech info stickey at the top of this section.
Old Nov 2, 2003 | 07:11 PM
red4691's Avatar
red4691
Thanks, I'll print it off and take it with me, that's the thing, I don't know anything about Ford, what started when, what is in what. I've owned one Ford, 70 LTD, needless to say it was easy to work on!
Lance
RL7
1997 - 2003 F150
25
Jan 6, 2025 02:15 AM
79str8six
Apr 15, 2012 06:53 PM
danthurs
Aug 1, 2011 08:25 PM
mb43
Sep 21, 2004 12:14 PM
lala
May 27, 2004 02:27 PM
