Water Pump
Old Apr 14, 2001 | 06:03 AM
jessbass's Avatar
jessbass
Water Pump
I replaced the water pump on my 82' F100 (300) yesterday and was pleased at how easy it was (except for having to remove the radiator). Anyway, I just read a previous post regarding adding thread sealant to the bolts when replacing the pump since several of the bolts go through the water jacket. Of course, I didn't do this. I inspected the new pump several times and have no leaks. My question is, anyone else out there do the same thing I did and not put sealant on the bolts threads, and if so, did you develop leaks around the bolts later on? Also, a hint for those 'not so experienced' mechanics like me, if you replace the original fan with a flex fan, wear long sleeves and gloves while working with the new fan or stock up on plenty of bandaids before you start the installation!
Old Apr 14, 2001 | 11:39 AM
PAUL_2's Avatar
PAUL_2
Water Pump
I think 3 of the 4 bolts holding the water pump to the block go into the water jacket . Was there any residual sealant left on the bolts when you installed them ? It may be the older blocks had blind bolt holes & didnt require sealant on the bolts ? I would think that if it didnt leak right away it wouldnt leak at all , but who knows . If they leak you ll have to remove them & seal them .
Old Apr 14, 2001 | 02:34 PM
jessbass's Avatar
jessbass
Water Pump
[font size="1" color="#FF0000"]LAST EDITED ON 14-Apr-01 AT 03:37 PM (EST)[/font][p]I did notice that the bolts had some sort of black gunk around the threads because I almost soaked them in gasoline but decided not to. Checked things out this morning before starting engine and no leaks. Ran the truck most of today and still no leaks. I hope it stays that way. Thanks!
Old Apr 15, 2001 | 02:49 AM
maverick70's Avatar
maverick70
Water Pump
mozzles
40
Aug 29, 2014 10:53 PM
Mikeman
Aerostar
Sep 27, 2013 01:07 PM
nnewman
Jul 27, 2010 11:55 AM
00Dave
25
Feb 18, 2008 05:57 AM
b4hntn
1978 - 1996 Big Bronco
Jul 2, 2006 05:43 PM
