speedometer question
Old Dec 14, 2007 | 06:48 PM
cana55's Avatar
cana55
I have a 47 ford pickup running a C4 trans. The aftermarket speedo is acting up and i was wondering if anyone knows if you can run a harley bike speedometer that is 1:1 connected to this setup and if so what is required to ensure it is accurate.
Old Jan 2, 2008 | 05:44 AM
Mich 41's Avatar
Mich 41
Speedometer solution
Hi,
hard to say what will be the outcome if you connect the bike speedometer.
I had a similar problem on my '41 with a speedometer of a VW Bug, Nissan gearbox , Transit rear axle on 14" wheels. The reading needet to be pretty accurate in order to get a road registration in Germany. Here's what I did: I connected a electronic pick-up from a truck to a VDO Speedometer. In order to connect the pick-up to the gearbox I had the Nissan speedometer cable modified to fit the pick-up. The VDO speedometer can be adjusted in 2 way's : either you know how many impulses are generated by the pick-up per mile, or you set the speedometer in a learning mode, drive the exact distance of a mile , setting it back so it "knows" how many impulses he's got.
I set it approximatively , checked with the speed read of a GPS navigation system and changed the impulse figure until the reading was about 6% above the real speed.
Electronic pick-ups are available for most gearboxes, just check with your local reseller of gauges.
Hope this helps.
Greetings from Luxembourg, Gabby.
purecty
Sep 17, 2011 05:09 AM
shia1
1978 - 1996 Big Bronco
May 26, 2009 04:32 AM
hansosc
Sep 11, 2007 06:28 AM
BrentsSF
Jan 4, 2005 11:19 PM
busdriver1
Dec 5, 2001 07:09 PM
