e-brake pedal assembly
Old Dec 13, 2007 | 02:39 PM
bigperm2's Avatar
bigperm2
The short version of the this question is... Will the e-brake pedal assembly on a 1973 2wd F-250 interchange with the e-brake pedal assembly on a 1978 4x4 F-250?
The background is... I am halfway through the cab swap project with a '73 2wd f250 cab and `78 4x4 F250 chassis. I need to order the front e-brake cable, and I am under the assumption that I should order one for the 1978 4x4. But the 1973 2wd is a different part, and I would like to be sure that the '78 cable will fit in the '73 pedal assembly (I don't have the '78 assembly.) So the reason for the question, is I am not sure that the part# is different due to the chassis, or if it is different due to the pedal assembly, or both!
Any info is greatly appreciated! -D
Old Dec 13, 2007 | 04:27 PM
Mil1ion's Avatar
Mil1ion
Same wheelbase ?
73-75
76/79
dipstick429
Mar 1, 2015 12:12 PM
jimbone422
Dec 31, 2012 03:40 PM
skrch2
Jan 26, 2011 02:54 PM
fordman1090
Mar 23, 2010 05:32 PM
gd2227
1997 - 2003 F150
Mar 3, 2010 09:22 PM
