master cylinder rod
Old Dec 11, 2007 | 05:23 PM
rmalottwtes30's Avatar
rmalottwtes30
master cylinder rod
What length rod do I need to go from the booster to the brake pedel? Im using the master cylinder and booster from my 76 but the lenghth of the rod is different. I measured the height of the pedel to the floor and there is a 2 inch differnce in the two. I cannot change the whole pedel assembly out because on the 76 its all broken...im putting it on my 77 f100... Anyone got a link or part number on what I need?
Old Dec 11, 2007 | 06:55 PM
Mil1ion's Avatar
Mil1ion
You need the correct BOOSTER like I mentioned before and I mentioned what you needed.
The push rod is part of the booster assembly
You can't mix and match.
Old Dec 11, 2007 | 07:49 PM
rmalottwtes30
im talking about the top part not whats on booster itself... Maybe thats what I need and Im guessing its a junk yard item? When I got that booster it didnt come with the flat rod...or are the all the same? And its just the rod attached to the booster longer?
Old Dec 11, 2007 | 07:56 PM
rmalottwtes30
https://www.ford-trucks.com/user_gal...170503.520.390
Old Dec 11, 2007 | 08:22 PM
Mil1ion's Avatar
Mil1ion
That fulcrum mount is on the firewall and is what the booster mounts to.
See the application per the 1977 as they are different than previous years.
It is far from just picking up any booster will do...... thinking.
Your 1977 F100 requires OEM booster D7TZ-2005 -H
That translates to precisoon booster rnumber
5012296 or *12296*.
The photo of the booster above is the one you need. Plus the 1977 fulcrum mounting Bracket/Pedal and pedal assembly.
Old Dec 11, 2007 | 08:30 PM
rmalottwtes30
Where can I get a 1977 fulcrum mounting Bracket? now that I know what it is called. How different are the 77 and 76 fulcrum mounting brackets?
Old Dec 11, 2007 | 08:40 PM
Mil1ion's Avatar
Mil1ion
76's don't have them.... they were a straight thru push rod style.
Does your 77 not have any brake asembly parts ?
Old Dec 11, 2007 | 11:39 PM
NewF100's Avatar
NewF100
Hey Mil1ion,
I'm converting my 75' F-100 4X4 to front disc. Any Idea what booster and master combo I would need.
Old Dec 12, 2007 | 05:34 AM
rmalottwtes30
Well when i had the 76 I must of got the fulcrom off a 77 or later model cuz I got that on the truck. When I got the 1977 it wasnt power brakes so i jsut took all the stuff off the 76 to put on the 77, but the lenght of that rod i suppose is to short or its the brake booster rod making the fulcrom not be able to extend all the way. I would just change out pedel assemblys but the one on the 76 is all tore up... I want to get this right.... So I guess the rod lenghts on booster on 76 are different length on 77?
Old Dec 12, 2007 | 09:58 AM
Mil1ion's Avatar
Mil1ion
Originally Posted by NewF100
Hey Mil1ion,
Booster : The last part listed (very bottom) on post #2
Master cylinder is
Old Dec 12, 2007 | 10:00 AM
Mil1ion's Avatar
Mil1ion
Entirely different boosters.
Do you want cruise control or not ?
Old Dec 12, 2007 | 01:37 PM
rmalottwtes30
I dont want cruise. just regular old power brakes... I searched partsamerica.com and it kept coming up with the same part number for the 76 and 77...
Old Dec 12, 2007 | 02:01 PM
Mil1ion's Avatar
Mil1ion
Not for me.
77- 79 (before DJ0001)
http://www.partsamerica.com/ProductD...pe=250&PTSet=A
Old Dec 12, 2007 | 02:18 PM
rmalottwtes30
Hmm i must of been reading it wrong or something.... So about the fulcrum how do I know if it is a 1977?
I assume I will also need a new master cylinder?
Old Dec 12, 2007 | 02:22 PM
Mil1ion's Avatar
Mil1ion
That's right they don't have a bracket
Any bracket from 1977 to DJ0001 on a 79 will work.
You should try to find the whole brake assemby in a parts truck.
That way you have a core
