1978 - 1996 Big Bronco
Axle ID'ing
Old Dec 13, 2007 | 12:01 PM
BroncoBrad's Avatar
BroncoBrad
Question Axle ID'ing
1988 FSB 4X4 auto w\OD 302FI
I need to replace my front shocks, quad shock set-up. Shox are decided by what front axle I have. I have limited slip, but I need to know if it is Dana 44, 50, 60. Can't find anything obvious. Before I buy the shox can someone give me a clue to ID the front? Thanks!
Old Dec 13, 2007 | 12:50 PM
Kemicalburns's Avatar
Kemicalburns
all broncos have ford TTB Dana 44.
Old Dec 13, 2007 | 05:06 PM
BroncoBrad's Avatar
BroncoBrad
Question Thanks Kemical
Just what I needed! Thanks! So is the rear a 44, 50 or 60? My Dodge PW had a 60 rear, 50 front. Just wondering. Sorry, did I say the D word?
My family knows, when I go, I want them to bury me with the Bronco!
Old Dec 13, 2007 | 05:38 PM
andym's Avatar
andym
The rear is a Ford 8.8".
Old Dec 13, 2007 | 09:48 PM
BroncoBrad's Avatar
BroncoBrad
Thanks
An 8.8" huh, I'll scribble it down somewhere. Thanks!
When I go, I go Bronco! Sorry, I'm having a geek attack. Beer and BBq tonight in 45 degree weather. Thanks again!
Old Dec 14, 2007 | 09:41 PM
shift1313's Avatar
shift1313
was the 9" rear an option on the bronco?
the ford 8.8 is an 8.8" ring gear. That axle was run in lots of vehicles in different forms including mustangs. The rear cover has 10bolts holding it on the diff housing. The other truck axle was the 9" but im not sure if it was in the broncos, i think it was an option but im not sure. the ford 9" has a removable carrier, so no rear cover. thats a real easy way to tell. You unbolt the carrier from the drive shaft side and makes for quick gear changes.
Old Dec 15, 2007 | 07:07 PM
bronco1989's Avatar
bronco1989
older bronco's i beleive had the 9'. but i might be wrong. he has the ttb front and 8.8 rear
Old Dec 15, 2007 | 07:23 PM
godblessmud's Avatar
godblessmud
1977.5-79 had 9" after that its always been the 8.8"
Old Dec 15, 2007 | 07:57 PM
shift1313's Avatar
shift1313
i was always curious cause ive never seen one under a bronco. but every time i go to buy a diff cover gasket they ask me if i have an 8.8 or a 9".
Old Dec 15, 2007 | 08:36 PM
godblessmud
Its such a common swap that they probably just ask out of habit.
Old Dec 15, 2007 | 11:31 PM
Aciancio's Avatar
Aciancio
My 85 has a 9", I think most of your pre 86 broncos had a 9" with a few of the later ones having the 8.8" then 86 and up was the other way with most of the broncos having the 8.8" and the 9" as an option.
Old Dec 16, 2007 | 06:58 PM
andym's Avatar
andym
This is not correct. For one, Broncos came out in 1978, not 77.5. The 9" axle was developed much earlier than 1977, and was used in trucks and Broncos as late as 1986, and was phased out by the 8.8" starting in 1983.
Old Dec 17, 2007 | 11:00 AM
toolman's Avatar
toolman
Why swap from the 8.8 to the 9 ? Just curious....
Thanks !
-Scott in Spokane
hasteranger
Aug 13, 2010 01:07 AM
MN_Viking
Feb 18, 2010 09:42 PM
FarmingFord
Jun 2, 2009 10:40 AM
86F150302
24
Apr 17, 2009 02:31 AM
quickstreetcivic
1997 - 2003 F150
Feb 5, 2008 02:49 AM
