Hazard Lights
Old Dec 13, 2007 | 10:20 AM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
Hazard Lights
Okay, new problem. I tried to put my Hazards on the other day and only the left side would blink. What should I look at first, I am not sure even where to start to fix this issue. I would assume the first thing would be the connection for the right side but where would you find that. Do I have to pull the steering column apart? Too many questions, not sure what to do to fix this. It isn't a major issue but an irritating one.
Ted
Old Dec 15, 2007 | 12:48 PM
twg1966's Avatar
twg1966
Well, I don't guess anyone has any ideas on what to do. Does anyone know of any books on trouble shooting the electrical on a Ranger?
Old Dec 15, 2007 | 02:57 PM
87 XLT's Avatar
87 XLT
The factory wiring diagrams for my 87 Ranger show that the ONLY difference between turn signals & emergency flashers is in the multifunction switch.
Dont know what your driving, but if it's an 87 & the turn signals work fine you need to replace the multifunction switch.
The only wiring diagrams worth having are the ones from the factory. Same as a Dealer uses
The wiring diagrams in a Haynes manual are pathetic.
Old Dec 16, 2007 | 12:43 PM
twg1966's Avatar
twg1966
Thank you for the response. I didn't even think the multiswitch would cause so many problems.
Old Dec 16, 2007 | 12:54 PM
michigan66's Avatar
michigan66
Does your right rear brake light work? Do your right side turn signals work? If they don't, you have a wiring/ground problem - possibly a corroded connector. If the do work, the multifunction switch is your likely culprit. Good luck.
Old Dec 17, 2007 | 09:20 AM
twg1966's Avatar
twg1966
All lights function correctly except the hazards, and they suddenly started working properly last evening. I will put the multiswitch on the list of things to replace. Thanks.
Old Dec 18, 2007 | 05:36 AM
michigan66's Avatar
michigan66
You might also want to check the hazard flasher unit on the fuse box. There are two relays - one for turn signals and one for the hazard lights.
Old Dec 18, 2007 | 10:31 PM
Noah05's Avatar
Noah05
Check this first:
When you turned on the hazards was your turn signal lever up or down? If I remeber correctly if the turn signal is enabled and the truck is off the flasher won't active if you depress the brake or turn the hazards on.
Old Dec 20, 2007 | 02:18 PM
twg1966's Avatar
twg1966
Well, I was on the side of the road after my wife had an accident and put the flashers on and only the left side would flash. Blinker switch was not engaged. This happened for several days, then I put the flashers on at home one evening and the worked fine. I did not have the clutch or brakes engaged in either scenario. I am also having problems with my wipers coming on at random times. Nothing more than an inconvenience, but still it isn't normal. I do believe that I will check the relays first. Then work toward the multiswitch. I am going to have to replace my cruise control buttons as well. So I might wait until I get all the parts then try to fix both at the same time. I bought this truck recently and have already had to fix the a/c (warm days down in South Texas) change out an O2 sensor, fix the cat, put new rubber on the road and fix the brakes. It almost appears to me the previous owner wasn't into normal maintenance, so I guess I just better be prepared for all sorts of little to large issues. This is my new daily driver as the F350 burned too much diesel at 66 cents a gallon more than gasoline.
Old Dec 20, 2007 | 03:11 PM
5.0B2's Avatar
5.0B2
Your wipers are part of the multi-function switch also
Old Dec 20, 2007 | 04:23 PM
twg1966's Avatar
twg1966
I did have that one figured out must not have come across clearly.
chesire17201
22
May 27, 2018 12:42 AM
mario9272
Jul 8, 2013 11:03 AM
Tomahak
Jan 26, 2013 12:47 PM
SparkyRnD
Sep 8, 2010 03:17 PM
ford&willys
Electrical Systems/Wiring
Sep 12, 2004 09:17 PM
