Leveling question.
Old Dec 12, 2007 | 10:01 PM
FoxRacin17's Avatar
FoxRacin17
Leveling question.
Ok, my sister just got a 94 Ranger 4X4 with the 4.0L. It sits extremely un-level. Its pretty bad. What can be done to fix this problem? It doesnt have t-bars I guess from reading on here. Ive read that F-150 coils will work. Ive read that Bronco 2 coils will work. Ive read that leveling kits pretty much suck. So what should we do?
What work is required to do the F-150 coils? What parts are required for that too? Do we need new shocks for this? This seems like the best way to go i guess.
Does anybody make a coil kit for the Ranger to level it out? Or a good leveling kit that dont screw anything up.
Were putting 31x10.50s on it too so we have to do something. Please let me know what the best ways are.
Thanks.
Old Dec 12, 2007 | 10:48 PM
hunter1988's Avatar
hunter1988
http://www.roughcountry.com/ford_83-97_midsize_leveling.html
haven't used them, but I have the same truck and would like to...My stock tires were p265 on 15" rims. I replaced them with 31x10.5 BFG without a lift and didn't have any trouble
Old Dec 12, 2007 | 11:27 PM
FoxRacin17's Avatar
FoxRacin17
looks great. i think that is what we'll do. ill let ya know how it goes. i think we'll need a spring compresser though right? that is exactly the kind of thing were lookin for. thanks.
Old Dec 12, 2007 | 11:35 PM
hunter1988's Avatar
hunter1988
from what I hear a spring compressor helps keep your head in one piece. My dad was in the ER with my little brother once and I guess there was a guy in there who had the spring hit him in the face and broke is jaw and eye socket in several places. Good luck and play it safe.
Old Dec 13, 2007 | 05:00 AM
wendell borror's Avatar
wendell borror
You don't have coil springs to do the conversion, you have t-bars. The easiest way to level your truck is to crank the t-bars.
Old Dec 13, 2007 | 08:56 AM
hunter1988's Avatar
hunter1988
the 94 has the springs and no torsion bars... didnt they start the tbars in 1998?
Old Dec 13, 2007 | 09:08 AM
Rags's Avatar
Rags
I have a 94 that used to sag in the front, I got front springs from advance Auto parts, $100 Called Extra Load Springs. And I also Have 31X10.50X15 Tires and truck sits just right now.
They were a little bit of work to replace.
If you want to see how it sits, it's in my gallery
Old Dec 13, 2007 | 09:20 AM
smokn03's Avatar
smokn03
you shouldn't need a spring compressor.just undo the springs and jack the truck up from the frame.thats how did my f-150 when i put a 6inch lift on it.
Old Dec 13, 2007 | 08:34 PM
FoxRacin17's Avatar
FoxRacin17
looks pretty good. them springs from rough country are just $110 with free shipping. so ill probably order those. then i dont have to do any more research. they do the same thing though. thats what we want. ours sits really low. its gonna be equipped with 31x10.50-15s soon. Cooper Discover STTs. With them springs and tires, it is gonna look sweet! ill post before and after pics when we do it.
Ani i am wondering if you needed a alignment too?
Old Dec 13, 2007 | 09:53 PM
Rags's Avatar
Rags
No alignment needed, the tires have worn perfect for 2 years now ( about 20K Miles ), The springs were not to bad to do, you have to dicconnect the strutt arm from the cross member, disconnect the bottom of the shock, put a jack stand under the frame and let the front suspension hang, you may even have to pry it down a bit when ready to remove the old spring and even more when installing the new one.
The fun is removeing the nut inside the spring!
Old Dec 13, 2007 | 11:23 PM
FoxRacin17's Avatar
FoxRacin17
did you use a compressor tool? what other specialty tools are required if any? that doesnt sound too hard. why do you have to disconnect the strutt arm? if you had a compressor tool, wouldnt that compress it enough to just slide it out?
as for that bolt, we have some massive torque wrenches.
Old Dec 14, 2007 | 04:48 AM
wendell borror
Sorry, I was thinking his truck was an 04!!!!!!!!!
Old Dec 14, 2007 | 06:38 AM
cddz's Avatar
cddz
After replacing the front springs with leveling springs you WILL need an alignment. LOL your camber will be at least 2deg positive. I bought a set of skyjacker i did not need any special tools or compresors. took me about an hour a side.
Old Dec 14, 2007 | 06:54 AM
Rags's Avatar
Rags
A spring compressor is the 1 thing I don't have, besides I think it is alot safer without useing them if at all possible.
I didn't need an alignment, my tires sat perfect! and are wearing perfect. just remember to give your suspension a few days to settle before you make any other decisions.
I'm happy with the results I got for the money and time involved!
Old May 18, 2008 | 07:32 PM
whitebassbenny's Avatar
whitebassbenny
bump.
foxracin
did u go ahead with the new coils or has anyone else ?
Im just woundering what it looks like when its done(pics?). I got re-thinking about doing it to mine again this year.
ravens fan
Jun 22, 2013 10:53 AM
CBBeaty
6.7L Power Stroke Diesel
Mar 6, 2013 04:58 PM
Borrego97
May 14, 2010 02:49 PM
F250_
19
Mar 9, 2009 08:57 PM
