HELP!, leveling kit questions
Old Jun 20, 2013 | 06:08 PM
ravens fan's Avatar
ravens fan
ok so im in the process of putting a 2 inch leveling kit on my 91 f150 4X4 we are also replacing the radius arm bushings but running into a few issues
my question is how do you take tension off of the spring? we took the top nut of and it is loose but the spring is too tight to come out, do you have to take the tie rob end off?
and what is the best way to get the old camber bushing out? we have tried heat and chiseling at it without any luck
any help is appreciated thanks!
Old Jun 20, 2013 | 08:25 PM
Krazywolf8169's Avatar
Krazywolf8169
The camber bushings can be a real pain. If you already have the steering knuckle removed try a ball joint press to remove the camber bushings
Old Jun 20, 2013 | 10:46 PM
ravens fan's Avatar
ravens fan
thanks krazywolf
Old Jun 22, 2013 | 10:53 AM
CATM1's Avatar
CATM1
I have use the gear pull tool to remove bushing. it work
Olga M
DeputyDiesel
Nov 25, 2018 07:55 PM
v8xploder
1978 - 1996 Big Bronco
May 27, 2010 02:47 PM
ibaneznik
Jan 7, 2007 09:59 PM
pdqtimetrialer
Aug 12, 2006 10:21 AM
