valve cover gasket plug burned
91: I feel your pain, I was wondering the same thing today when the gasket and GP/Inj harness had a cook out. I don't know the answer to your question but I'd be surprized if Ford didnt tell you that you had to buy the whole top harness. If that should happen the junk yard would be my best bet unless there is an after market replacement.
TJ, C00nHunter and the other Guru's should be more of a help.
Good luck 91,
Rog
Good luck 91,
Rog
I was just playing around in AutoZone and some how I got into an area that had 180 Ford Tech. Service Bulletons 89 through 99 maybe 2000.
Anyway there were three that pretained to:
"Terminal Repair and Splice Kits"
#98-11-3 06-08-98
#99-6-3 04-05-99
#01-10-12 05-28-01
I don't know if these will be of any help but it may be worth a try, at least you may find that there are in fact replacement plugs of some type.
Rog
#98-11-3 06-08-98
#99-6-3 04-05-99
#01-10-12 05-28-01
Rog
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve Cover Pigtails with plug and wires, OBS
(Performance Specialties) 99288
Valve cover harness replacement terminals:
Industry P/N 103935; Winzer Distributing (1-800-527-4126) selection number D52
Valve Cover Harness "Wedge" repair (not sure of years it fits or what it looks like)
(Ford) 2c3z-14a163-ab
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
Hey guys i'm having a mental laps right now but pigtails are available.I just repaired mine,can't remember name of place in Indy #is 317-808-1500 ask for harness repair kit includes pigtails w/8inof wire.Color codes are basically the same w/ostripes easy repair.I think the name of the place is Powerstroke Store???
PAUL_2
04-18-2004 12:48 PM
