CCV Mod Question
Old Dec 10, 2007 | 07:37 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
CCV Mod Question
How do you guys seal off the original port into the intake, and what the heck is the little green line for?
Thanks.
Old Dec 10, 2007 | 07:43 PM
Izzy351's Avatar
Izzy351
Remove the CCV coupler and replace it with a piece of stainless 4" exhaust pipe. I used a 3" ID PVC coupler, but I do plan on putting in a piece of exhaust pipe when I get my hands on one.
Old Dec 10, 2007 | 07:44 PM
monsterbaby's Avatar
monsterbaby
on the CCV I took that piece of plastic out and replaced it with a piece of 4" exhaust pipe.
Old Dec 10, 2007 | 07:55 PM
joegebff's Avatar
joegebff
And the little green hose?
Old Dec 10, 2007 | 07:58 PM
monsterbaby
I think it has something to do with being a vent for the controller for the waste gate, but not 100% sure.
Old Dec 10, 2007 | 08:04 PM
Izzy351's Avatar
Izzy351
Yeah, I believe it vents off boost to the intake when it's not needed to open the wastegate.
Old Dec 10, 2007 | 08:17 PM
DaveWilliams's Avatar
DaveWilliams
Dont mess with the green line...
Thanks.
Hey I am not sure exactly what the GREEN line does, but it is down stream of the plastic piece you remove and replace with exhaust pipe. Looking back at some pictures of the PRE CCV mod, the green line is on the turbo side of the CCV. You just remove the plastic piece and simply install the 4 inch exhaust pipe or whatever material you choose to use, and hook the plastic intake tube back to it. Save a piece of the 4 inch exhaust for the 6637 filter too...
This picture is not my setup but one I used for instructional purposes...
Old Dec 10, 2007 | 09:08 PM
ijuslikefords's Avatar
ijuslikefords
I used a piece of 4" aluminum tubing I got here http://stores.channeladvisor.com/ver...bing/Aluminum/
Old Dec 10, 2007 | 11:28 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Yah just use a piece of 4 inch exhaust piping and while your at it I suggest you do the 6637 air filter mod,
Nick
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
