What the ???? would cause this?
Old Dec 11, 2007 | 04:14 PM
  #31
Benny2002's Avatar
Benny2002
Kris one other thought on this situation is going to a coil over system. Im not sure what you had in a budget for injectors and the turbo parts to use them but you could go with a coil over kit and be done for good with leaf springs all together. DC probably could point you to a good kit.
Old Dec 11, 2007 | 04:17 PM
  #32
DCSpecial's Avatar
DCSpecial
Coilover conversion would be PIMP........I may eventually do it to my 01 (although I've been trying to stop changing stuff on it). Full Traction is the only kit I would run short of One Up Offroad.
FT has a 4", 6" and 8" kit (figure $2400 for the front kit and $1300 for 2.5" diameter coilovers though).
Those are guesstimates on the pricing......I'm no longer in the game so I don't know if they have changed.
Old Dec 11, 2007 | 04:57 PM
  #33
jtharvey's Avatar
jtharvey
Originally Posted by Izzy351
FWIW, I looked at my driver-side rear spring and my bottom leaf is starting to shift as well.
Mine's like that too. It's been like that for at least a couple years. It's not moved any more during that time though.
Old Dec 11, 2007 | 05:41 PM
  #34
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I contacted my buddy who has a dealer's license, they can get me a Donahoe Racing 4" all-spring, which means replacing the rear with springs as well, plus the box kit for $1380 which is just $50 more than i can get at retail with just front springs and rear blocks. I always wanted rear springs on a 4" kit but i did not know that was possible. Plus the LR spring is basically shot too, it is phagged. Hmm, decisions decisions, decisions.
Old Dec 11, 2007 | 06:00 PM
  #35
DCSpecial's Avatar
DCSpecial
Seems like a good deal...figure jobber on the front and rear springs is $590 per pair, $80 or so for the rear u-bolts , and the box kit jobbers for $375
Jobber is the lowest any DR can sell DR w/o risking losing the ability to sell DR (they can pull the product if you violate it).
If he is quoting you all spring it would be the 4" fronts and the 5" rears. You would run the rears with NO block and the truck will be slightly azz high.
Old Dec 11, 2007 | 06:26 PM
  #36
jtharvey's Avatar
jtharvey
Better than the sag @$$ look. Kris, if you go this route, I need some after measurements from you. I need the distance from wheel center to center of the wheel well opening.
  #37
PowerstrokeJunkie
That's cool. It sits a little *** high as it is and it just needs to go up 2-3" all around.
Old Dec 12, 2007 | 04:15 PM
  #38
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Kris,
What is it that is causing your truck to lean to one side? Is it the cracked spring? Sway bar bushings?
Old Dec 12, 2007 | 04:38 PM
  #39
PowerstrokeJunkie
Tried to answer your PM but it timed out on me and i wasnt sure if it went through. Apparently not
The broken spring is causing it to lean to one side. If anything, the sway bar will try its hardest to keep level. But, when i disconnected the links nothing changed. Im betting you have a phagged spring, in other words, one that's "sprung".
Ive decided on the lift and i just gotta wait for another paycheck to pad the bank a little.
Old Dec 12, 2007 | 04:39 PM
  #40
Texas Outlaw
Not a liberal...
Thanks, Kris. I too think I have a bad spring. The left front is the culrpit I am pretty sure.
Thanks for your help.
Old Dec 12, 2007 | 04:46 PM
  #41
PowerstrokeJunkie
Want my front right?
Tom S
34
Sep 9, 2012 03:14 PM
ufospy
Projects
29
Aug 1, 2012 08:35 AM
BlueMule
32
Apr 11, 2012 08:17 PM
bigpowerstroke
13
Dec 24, 2010 12:28 PM
scottman70
Oct 27, 2010 05:24 PM
