Replacing Common Rail Fitting
Old May 23, 2004 | 06:54 PM
barebackjake's Avatar
barebackjake
Exclamation Replacing Common Rail Fitting
Ive got a fitting at on the common rail at the back of the driver side head leaking, how do i bleed the pressure off this thing before cracking it open to replace??? then how do you reprime a pstroke?? or do i not worry bout it and just fire it up and let it do it itself? probably just need to replace the oring inisde it
Old May 24, 2004 | 06:12 AM
fourstroke's Avatar
fourstroke
If it's leaking, there is no pressure when the engine is shut off. There is a seal inside the fitting, and depending on what year truck you have, somtimes the turbo pedestal has to be removed to take the fuel line off. After reassembly you will not need to prime the system, just fire it up.
Old May 24, 2004 | 09:05 AM
barebackjake
thanks fourstroke,
its a 97, im hoping i dont have to pull the turbo it dosnt look like i will have too, its only an intermitten leak only leaks when im not looking and leaks when i dont have time to find it
Old May 24, 2004 | 07:56 PM
fourstroke's Avatar
fourstroke
I believe the '97 has an updated line that is removable without pulling the pedestal. The seals are only a couple of buck's at Ford.
Old Dec 12, 2007 | 11:22 AM
joshsmith7's Avatar
joshsmith7
The oring on the head side of my fuel line is shot. Do I need to purchase a new line or can i just get an oring?
Old Dec 12, 2007 | 11:44 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Josh, this thread was started in 5-2004. Start another thread and ask that question.
Good luck.
Old Dec 12, 2007 | 02:15 PM
ron's power stroke's Avatar
ron's power stroke
fuel rail fuel line oring 1/4" part# IH 685158c1 1.88 each
this is for the 1/4 inch steel line going into the head..its under the nut on the line ... i hope thats what you need..thats where mine was leaking..
Old Dec 12, 2007 | 05:24 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I dont think you're talking about the fuel rail, are you? Do you mean the large diameter (1.5" or so) plug on the back of the head that takes a 1/2" ratchet head? First check to see if it's loose. I had a oil leak on the front right plug on the 95 which was easily fixed by just tightening it up. I had just reinstalled the engine and the plug somehow was loose, and just vibrated loose enough to leak.
