Hello all,
I'm enjoying my F250 now that the snow is falling. Does great!
I have a question about the block heater. I plugged it on once for 30 minutes and it didn't look like the engine warmed up any.
How long does everyone usually plug it in? Will it cycle on and off if I leave it plugged in all night?
How do I know it's working?
i'm in Texas and i've never plugged my truck up...so i really don't know, but i thought the block heater just kept the oil warm...someone will chime in to correct me, but thats what i've been told.
I have mine on a timer that trips on in the morning for three hours. Our block heaters usually need at least two hours to warm up properly.
There's probably a high-tech way of making sure it works...but plug it in for a few hours and then go out and put your hand on the top of the radiator. It should feel warm.
Might want to double check your plugin to make sure it isn't cracked or freyed I had to replace my plugin last winter. Also make sure your outlet is working block heaters pull a lot of power and like to trip breakers.
Yeah i think i read somewhere that ford recommends 3-4 hours plugged in. A timer is nice though because I don't really feel like plugging the thing in at 4 in the morning.
Honestly, for the $10, a timer's the only way-to-go. We have 2 diesels plugged in, I definitely don't want 2 of them burning all night, even if I just had the one, I'd still have a timer on it.
Man, you'll get all kinds of answers on this one I plug in around the 30's, to me, it's just easier on the whole system, electrical, oil, mechanical, everything. Why work things harder than need be? but that's just my opinion.
I've never plugged mine in either, but I've "only" seen temps in the upper 20s... It's currently in the mid 30s here in North Texas, but I keep mine in the garage so it doesn't really see the really cold stuff overnight. But even the few times I've left it out, it's done fine. No romps, no starting problems. no white smoke.
Ditto. 30's is about when I decide to plug in. Harder on the motor to run/start real cold like that.
You need something that will handle at least 15 amps. Same story with your extension cord...get a heavy duty one that won't melt on ya.
I got an 18 amp heavy duty outdoor waterproof timer from Home Depot for $18. Right now is probably a good time to buy one because of the Christmas season and people need them for holiday lights and whatnot.
If it's a 1500W load, that's 12.5A at 120V so a 15A timer will work. But you can't go wrong with a HD timer -- better to have the bigger version than to push the limits on a regular one...
Yep, I'm always going with the better safe than sorry route, good heavy extension cord and HD timer, but my timer's in the garage so I didn't worry bout the waterproof.
