Block Heater
Old Dec 10, 2007 | 09:54 AM
CPT_Diesel's Avatar
CPT_Diesel
Block Heater
Hello all,
I'm enjoying my F250 now that the snow is falling. Does great!
I have a question about the block heater. I plugged it on once for 30 minutes and it didn't look like the engine warmed up any.
How long does everyone usually plug it in? Will it cycle on and off if I leave it plugged in all night?
How do I know it's working?
Thanks!
Old Dec 10, 2007 | 09:59 AM
03_PSD's Avatar
03_PSD
i'm in Texas and i've never plugged my truck up...so i really don't know, but i thought the block heater just kept the oil warm...someone will chime in to correct me, but thats what i've been told.
Old Dec 10, 2007 | 10:01 AM
Smokin''s Avatar
Smokin'
Smokin
I have mine on a timer that trips on in the morning for three hours. Our block heaters usually need at least two hours to warm up properly.
There's probably a high-tech way of making sure it works...but plug it in for a few hours and then go out and put your hand on the top of the radiator. It should feel warm.
Might want to double check your plugin to make sure it isn't cracked or freyed I had to replace my plugin last winter. Also make sure your outlet is working block heaters pull a lot of power and like to trip breakers.
Old Dec 10, 2007 | 11:04 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
I have mine on a timer also for about 3 hours. I've had it set for as little as 2 hours. I doubt you'd see much in 30 minutes though.
Old Dec 10, 2007 | 11:46 AM
edub32's Avatar
edub32
Yeah i think i read somewhere that ford recommends 3-4 hours plugged in. A timer is nice though because I don't really feel like plugging the thing in at 4 in the morning.
Old Dec 10, 2007 | 11:52 AM
TurtleRacing
PSD Addict
Honestly, for the $10, a timer's the only way-to-go. We have 2 diesels plugged in, I definitely don't want 2 of them burning all night, even if I just had the one, I'd still have a timer on it.
Old Dec 10, 2007 | 11:57 AM
03_PSD's Avatar
03_PSD
how cold do you guys wait to plug it in?
Old Dec 10, 2007 | 12:00 PM
TurtleRacing
PSD Addict
Man, you'll get all kinds of answers on this one I plug in around the 30's, to me, it's just easier on the whole system, electrical, oil, mechanical, everything. Why work things harder than need be? but that's just my opinion.
Old Dec 10, 2007 | 12:06 PM
Izzy351's Avatar
Izzy351
I've never plugged mine in either, but I've "only" seen temps in the upper 20s... It's currently in the mid 30s here in North Texas, but I keep mine in the garage so it doesn't really see the really cold stuff overnight. But even the few times I've left it out, it's done fine. No romps, no starting problems. no white smoke.
Old Dec 10, 2007 | 12:33 PM
Smokin''s Avatar
Smokin'
Smokin
Ditto. 30's is about when I decide to plug in. Harder on the motor to run/start real cold like that.
Old Dec 10, 2007 | 01:02 PM
CPT_Diesel's Avatar
CPT_Diesel
Cool. It was close to 0 the other week. Lots of snow and wind.
Do you have to use a heavy duty timer, or just any old timer?
Old Dec 10, 2007 | 01:05 PM
TurtleRacing
PSD Addict
I use heavy duties, but I've seen 'regulars' that were supossed to be good for 15 amps so I'm not positive it matters.
Old Dec 10, 2007 | 01:07 PM
Smokin''s Avatar
Smokin'
Smokin
You need something that will handle at least 15 amps. Same story with your extension cord...get a heavy duty one that won't melt on ya.
I got an 18 amp heavy duty outdoor waterproof timer from Home Depot for $18. Right now is probably a good time to buy one because of the Christmas season and people need them for holiday lights and whatnot.
Old Dec 10, 2007 | 01:11 PM
Izzy351's Avatar
Izzy351
If it's a 1500W load, that's 12.5A at 120V so a 15A timer will work. But you can't go wrong with a HD timer -- better to have the bigger version than to push the limits on a regular one...
Old Dec 10, 2007 | 01:15 PM
TurtleRacing
PSD Addict
Yep, I'm always going with the better safe than sorry route, good heavy extension cord and HD timer, but my timer's in the garage so I didn't worry bout the waterproof.
