Melted battery cable
Old Dec 9, 2007 | 02:32 PM
jamesdherman's Avatar
jamesdherman
The other day I went to start my 66 F250, and it wouldn't start. Was in a hurry, so I took my other car. Today I went to jump it and noticed the positive cable burnt thru near the starter solinoid. My question is, what would cause this? the previous owner put in a new solinoid and alternator. It's a newer cable too.
Old Dec 9, 2007 | 02:54 PM
ReAX's Avatar
ReAX
Shorts cause heat, the cable may have been nicked or damaged. Or it could not handle the current being pulled through it.
Old Dec 9, 2007 | 05:35 PM
Sawsall's Avatar
Sawsall
If the post wasn't tight or it had been made cheaply... a bad connection is like a very small wire... the amount of load pulled through the bad connection causes it to heat up and burn through...
Make sure the new cable is heavy enough and good and snug with all terminals cleaned... While your at it, also check the other connections.
moejr
Electrical Systems/Wiring
Dec 5, 2016 09:58 AM
huskyfan68
Feb 17, 2016 10:10 AM
Greg Rogers
Aug 2, 2015 06:25 AM
jshantz
1983 - 2012 Ranger & B-Series
Dec 13, 2008 07:30 PM
alan-r
Jan 18, 2007 04:54 PM
