starting problem ?
Old Jan 18, 2007 | 03:00 PM
alan-r's Avatar
alan-r
Red face starting problem ?
My 82 f100 6cyl. will not start. It ran fine 4 or 5 days ago but the temp has dropped down into the 20's and has been snowing the last couple of days.
When I try to start it I hear one loud click and that's it.
The battery voltage is 12.5v and does not drop when I turn the key. Everything works, lights, ect and continues to work when I try to start the truck.
I just went out and checked it a little further:
I have 12.5v at the battery.
11.8v at the small red wire on the solinoid with the key in start position.
0v on the starter side of the solinoid with the key in start postion.
I think I may have answered my own question. (Sounds like the solinoid).
Old Jan 18, 2007 | 04:54 PM
Franklin2's Avatar
Franklin2
You could possibly have a bad connection. Sounds like you have a meter and know how to use it, so try this;
Put your meter on the large post on the solenoid that goes to the bat +, and while holding it there, get someone to try to crank the engine. You may have 12.5v in that area at the beginning, but as soon as someone tries to start the truck, see if it drops close to zero. If it does, you most likely have a bad connection at the battery, at the engine block(ground), or a bad cable itself.
Just remember to check voltages under load when things are happening. Your voltages will be very different with the load of the starter on the wiring.
huskyfan68
Feb 22, 2016 08:33 AM
pat420swed
19
Nov 30, 2015 11:47 PM
bbacon
Jul 2, 2014 11:28 PM
rickpilgrim
Nov 20, 2012 12:07 AM
jshantz
1983 - 2012 Ranger & B-Series
Dec 13, 2008 07:30 PM
