Positive ground?
Old Jul 25, 2015 | 08:13 PM
Greg Rogers's Avatar
Greg Rogers
Positive ground?
Looking thru my new purchase 1956 F100 and there are many surprises and mysteries. I believe this truck is a mismatch of 2 trucks. A 55 and a 56. I think the 55's had 6 volt and the 56 was the first year for 12 volt. Is that correct? Also looking at the 56 service manual it looks like the black cable directly off the battery goes to the starter solinoid, and it shows the other cable going to ground. Red? Positive ground? All the wiring is in a crate and all the dash switches,etc are all disconnected. And help will be appreciated. Thanks, Greg.
Old Jul 25, 2015 | 08:25 PM
Harrier's Avatar
Harrier
You are correct. The 55 was 6v positive ground and the 56 is 12v negative ground.
The guys with the 56 wlll be able to give you more info on their wiring.
Take some pictures and show us what you have. What are your plans for the truck.
There is a lot of info on this site about wiring. You can spend hours searching through threads.
52 Merc's Avatar
52 Merc
You are correct that 55 was 6 volt positive ground and 56 was 12 volt negative ground. The polarity doesn't know anything about wire insulation color. Depending on which pole is grounded, the opposite one goes to the starter solenoid from the battery.
Old Aug 2, 2015 | 06:25 AM
Greg Rogers
Thanks guys
rchawaii
19
Mar 21, 2016 11:04 AM
Rich1953ard
Apr 17, 2013 11:10 AM
CrazyDog66
Feb 13, 2011 03:33 PM
TucsonCowan
18
Apr 8, 2007 05:27 PM
Scott
Oct 19, 2001 07:19 PM
