trading axles
Old Dec 8, 2007 | 09:05 PM
Dustin_86's Avatar
Dustin_86
Question trading axles
I want something stronger than the d 60 FF that is in the rear of my 78 f250. What about a dana 80 out of a 94-02 dodge, or are there to many diffrences to swap them in my 78. What about a sterling 10.25, I heard they give them away practically.
I'm looking for a wieght carrying axle, not nessisary the ability to handle big hp
Thanks,
dustin
Old Dec 8, 2007 | 09:11 PM
ynevada's Avatar
ynevada
and the 60 wont do what u want?
have u broke ur 60 from overloading it?
even if u put the biggest axle u can buy, the engine/trans/brakes are only good for so much weight.
u can upgrade the shafts. i think thats the weak link on the 60.
i know my 8" toy axles are the same diameter, and spline count as the 60 in my ford. and MUCH larger than the d44 axles in the front.
Old Dec 9, 2007 | 06:51 PM
Dustin_86's Avatar
Dustin_86
I have not broken the 60 yet but I don't want to I would like to make it stronger, because I'll be doing a frame off, upgrading everything, From the brakes to making eather boxing in the frame, or taking 1/8' metal plate and wraping in around the frame on the outside of the "C" all the way. If I put upgraded axle shafts and a extra capacity finned cover, and synthetic mobil 1, will the 60 handle the pin wieght of a 6 horse with living quarters. I figure 2400-3000lbs road ready pin wieght so that will put about 7500 in the little D 60 with the back of the truck loaded( I will run 19.5 load H tires/wheels from Rickson.
Old Dec 9, 2007 | 10:46 PM
gearhead351's Avatar
gearhead351
Put in a 14 bolt FF. yes a Cheby axle. I just got done putting mine in.........tonight. Was EXTREMELY worth it! Looks like it came from the factory this way!
Old Dec 10, 2007 | 12:41 AM
andym's Avatar
andym
The 14 bolt is a very strong axle, but I don't know if the rims are compatible. A sterling is also a very strong axle, so if you're brand-loyal then it's probably the way to go.
Old Dec 10, 2007 | 01:17 AM
gearhead351
my 16" wheels I ran on my dana 60 went right onto the 14 bolt. I had to get 9/16" lugz though.
lol
Dustin_86
Offroad & 4x4
Apr 28, 2006 06:43 AM
Dustin_86
Jun 21, 2005 08:50 AM
Dustin_86
Dec 14, 2004 11:21 PM
Dustin_86
Jul 14, 2004 06:41 PM
Dustin_86
Appearance & Dress-Up
May 17, 2004 06:09 PM
