P0266 Cylinder 2 Contribution/Balance
The following users liked this post:
Hey guys, 2006 F250 6.0 I am having a P2066 code that just showed up this morning and it seemed to have a little bit of smoke. Every day where it is under 60* outside, the truck will have a slight misfire and had no smoke so I changed my oil to 5W-40 T6 with 8 oz of Rev-X oil additive and I had FoMoCo 15W-40 in it and that seemed to help for a day or two. I just installed all 8 injectors (190/100 from warren) about a month ago so it seems like I wouldn't have a bad injector...does anyone know what it could be?
2013 f350
would this code come up if the fuel was felled up? I had a low fuel pressure in the fuel rail code come up as well both when it was cold as hell
does the code come off once it’s warmed up tho or does cylinder 2 stay on still after deleting it?
[QUOTE=Unrealo4;10060958]Could also be a ficm that is weak. One of trucks in our fleet throws cont/balance codes on random cylinders until it warms up. Its ficm is bad, going to try the resoldiering trick on Monday for it.[/QUOTE]
does the code come off once it’s warmed up tho or does cylinder 2 stay on after deleting it? My truck has cylinder 1&2 on when first driving and just today 2 won’t clear, runs good on highway and in town when up to temp but once it’s stopped or parked you can tell it’s a little choppy.
2003, 60, 73, balance, contribution, contributionbalance, cylinder, diesel, duty, f250, fault, ford, p0266, powerstroke, super
