I've been working on an 04 F-350 and it has an intermediant problem with the throttle droping out and having nothing but idle. It has recently had a new egr installed and a throttle pedal. Does anyone have a suggestion or can point me in the right direction. thanks for any help.
Yep--check the harness around the driverside valve cover, especially under the FICM. You probably don't have any kind of computer codes stored either, right?
there was actually a factory recall for this wiring harness have a dealership check your oasis and see if yours has been replaced yet or is a candidate for one.
sorry for the late reply, power is out from ice storm. no codes are in the ecm. haven't seen any chafed wires. Will look again. is the recall a ford mandatory one, or will they try to get out of it with high milage.
Chaffed wires rarely set a code, here is a link to the Safety recall "05S34 FICM Wiring HArness / ICP Harness Repair" pictures included.
