drivers side door panel
Old Dec 7, 2007 | 08:26 AM
RobertJohn's Avatar
RobertJohn
Are there any tricks or how is the easyiest way to remove the drivers side door panel ? I need to access the mirror switch and I may as well clean stuff while I'm there.. Do I need any special tools etc.. also, does it go back together the same way and do I need anything for the install ?
Thanks
Old Dec 7, 2007 | 08:35 AM
Izzy351's Avatar
Izzy351
Pop the power window switch panel up & reflector cover off. You should be able to pop the switch panel with your fingers. For the reflector, use a screwdriver. There are screws under those. Pull the connectors off the switches, remove the screws, then lift up on the panel -- should come right off. Rear doors are the same.
EDIT: BTW, get some plumber's grease at HD or Lowes -- it's like very thick vasoline. It works great on the power window tracks (there are three tracks in there). I did mine about 8 months ago and it made a big difference. I also sprayed some CRC silicone on the felt-looking tracks the glass slides up & down in.
Old Dec 13, 2007 | 07:15 PM
duct man's Avatar
duct man
Thank you i have been looking for this, now it is time to retune{ new speakers} an fix windows
Old Dec 14, 2007 | 11:43 AM
SpringerPop's Avatar
SpringerPop
Don't forget to remove the "sail panel" first. :-))
Pop
Old Dec 14, 2007 | 12:31 PM
RobertJohn's Avatar
RobertJohn
OK.....i'll show my ignorance....sail panels ?
Old Dec 14, 2007 | 01:34 PM
F350-6's Avatar
F350-6
Here's the link I used to remove mine.
http://www.eurekaboy.com/f250/doorremove.htm
Old Dec 14, 2007 | 04:20 PM
Meatco1's Avatar
Meatco1
F350-6:
That's a terrific link.
Thank you,
Richard
Old Dec 14, 2007 | 07:35 PM
F350-6's Avatar
F350-6
I've always been a fan of pictures. After seeing that link I try and take pictures of anything I do just in case someone down the road finds it useful. I encourage everyone else to do the same.
Old Dec 14, 2007 | 08:40 PM
Izzy351's Avatar
Izzy351
Great job on the pics, Chris!!
Old Dec 14, 2007 | 10:08 PM
RobertJohn's Avatar
RobertJohn
I agree...thats a gr8 page...tells me everything I need...
If there were more like that for all the other stuff wouldn't
life be grand...
reg1952
Nov 24, 2016 03:00 PM
SCFlareside
Feb 7, 2016 04:58 PM
likeagoodbook
Feb 11, 2013 07:09 PM
kris101966
2004 - 2008 F150
Jan 28, 2008 07:08 PM
mshostek
Paint & Bodywork
Oct 18, 2006 08:26 AM
