Aerostar Ford Aerostar
Tacho Installation.
Old Dec 9, 2007 | 07:13 PM
93nighthawk's Avatar
93nighthawk
Yes EDIS still have a spout connector.
As for mounting, make sure it stays out of your line of vision for driving, but you can still see it. Here is what I would do, take some double sided tape and just start mounting it in different places (without wiring it in) and see how you like it in each position.
Old Dec 9, 2007 | 08:42 PM
Aeroman59's Avatar
Aeroman59
O.K.then I'll try the grey connector with the tan /yellow wire first, hopefully thats the SPOUT, guess it wont take much to find out!
Pretty much decided to put the gauge on the top of the dash to the far left almost against the side window, where it curves down to the small triangular window panel. Good idea with the tape though, maybe I'll stick it there during next week & see how it goes.
ATB Aeroman
Old Dec 9, 2007 | 10:48 PM
DCRB's Avatar
DCRB
ATB Aeroman
thats where i placed mine, you don't notice it directly till it stops working ( i had to un hook it once then drive home like that) unless you actualy look for it.
Old Dec 12, 2007 | 08:01 AM
Pablo-UA's Avatar
Pablo-UA
Just a minute! Why not to use PIP signal from camshaft position sensor. 3 pulses per 1 cranckshaft revolution.
Old Dec 13, 2007 | 07:34 PM
Aeroman59's Avatar
Aeroman59
Yeah , just been on to the tech support & they tell me I've got the wrong tach, I need an upgraded version with the inductive pick-up coil to be compatible with DIS .
With the pu-coil it's $85 instead of $45, seems a lot of money for a p/u coil .
Anyhow I think I'm going to try it, the spout signal only seems to be a low volt circuit, & it does say not recomended to work with DIS systems. It does not say will not work.
Wont be happy if it smokes the EDIS module though !
ATB Aeroman
Old Dec 13, 2007 | 07:35 PM
Aeroman59's Avatar
Aeroman59
Thumbs down Wrong Tach
ATB Aeroman
dieselsmoker
6.7L Power Stroke Diesel
Jul 11, 2016 07:34 AM
Aeroman59
Aerostar
13
Dec 5, 2010 02:45 AM
Aeroman59
Aerostar
19
Dec 20, 2008 07:47 AM
Aeroman59
Aerostar
Nov 2, 2007 08:30 PM
Aeroman59
Aerostar
17
Aug 25, 2007 10:06 AM
