Aerostar Ford Aerostar
Plug mysteries Explained
Old Dec 15, 2008 | 07:24 PM
Aeroman59's Avatar
Aeroman59
Lots of you already know this stuff, but interesting all the same.
https://www.ford-trucks.com/forums/1...num-plugs.html
Old Dec 15, 2008 | 07:39 PM
99f350sd's Avatar
99f350sd
Funny cause I never had good luck with bosch plats in any vehicle..even my old 86 vw van. They would foul terrible van would barely run. took em out put in nippon denso plugs and good to go. Don't put them in a ford super duty either. Double plats for sure in my aero's.
Dick
Old Dec 15, 2008 | 08:01 PM
99f350sd's Avatar
99f350sd
By the way you can still get the PP765's on ebay I just bought 12 for $53.00 with ship.
Dick
Old Dec 15, 2008 | 09:40 PM
96_4wdr's Avatar
96_4wdr
good article
those of us with the 4L Cologne are also familiar with it's love to ping and preignite for the least reason.
plug temperature design range are critical on these engines for long head life and performance.
a correctly firing and running 4L is a thing of beauty in the on ramp wars.
Autolite and their buyer Motorcraft got the 4L double plats right the first time.
why risk a $1000 head replacement job on the wrong plug.
wife's HMC cars love the Bosch 2s. run strong with no misses. would not trust my Aero to them
Old Dec 16, 2008 | 03:26 AM
xlt4wd90's Avatar
xlt4wd90
I dunno, the 4 liter engine in my 1990 Aero has never pinged before, but its acceleration is pretty anemic in the best of tune.
I tried Bosch platinums in my 87 Mustang v8, and the engine definitely ran rougher than the Autolite/Motorcraft copper core plugs.
Old Dec 16, 2008 | 11:36 PM
99f350sd's Avatar
99f350sd
My 96 with 152,000 on it ran a little alot anemic until I ran 2 cans of seafoam in the gas tank. Now when you get on it it doesn't sound like a wheezing cat. It really opened up the intake cause you can here it growl just like my really nice 96. I'm happy as can be..
B4 it sounded like the exhaust was plugged. It went but not like the green one in the garage. Time for a drag race.
Dick
Old Dec 17, 2008 | 04:19 AM
96_4wdr's Avatar
96_4wdr
Seafoam or its lower cost more concentrated clone Berryman B12 is the cat's meow for the 4L especially.
suck a can in thru the TB plate hole and let her soak hot for 2 hours. take her out on the freeway and run her hard for 20 minutes.
burns and blows the carbon off the plugs, out of the ring grooves and cleans all the crud build up from TB plate to combustion chambers. it must burn/blow any carbon buildup off the CAT element also. mine sounds more throaty after a good B12 douche.
does nothing on the wife's Hondas.
i get the B12 here for $4 a can vs $10 for the SF.
i run Regane thru the tank to clean the fuel/injector system
Old Dec 17, 2008 | 10:15 AM
Bear River's Avatar
Bear River
Former ******
One of the reasons the Bosches don't work is their fine wire, makes the tip get hotter, and that in turn causes preignition, and also wears out the tip very rapidly. This is true of others as well. Autolite designed the plug to meet the requirements of Ford electrical system and stock compression ratios. The plug is designed to cool down very rapidly.
The Bosches might be the right gap, but hte heat range is wrong. They are designed for the voltage of say a Volkswagon, and that voltage is typically lower. So on a VW, there isn't as much heat from the spark itself, so the tip doesn't need to cool down as much, since it never got quite has hot.
Old Dec 17, 2008 | 10:16 PM
Bax2008's Avatar
Bax2008
I need to change plugs in my '95 3.0L in the spring.
What, specifically, should I be looking for?
*please describe, in essay form, 300 words or less, the pros and cons, etc.
Part numbers and prices, greatly appreciated.
Old Dec 18, 2008 | 09:37 AM
Bear River's Avatar
Bear River
Former ******
Just get the Autolite OE spec or get Motorcraft plugs. I order this stuff from Auto Parts Fast at RockAuto. They have great prices and they carry both brands.
Old Dec 18, 2008 | 12:23 PM
Bax2008's Avatar
Bax2008
I'll probably go to the dealer here.
Is there a premium plug available?
Old Dec 18, 2008 | 02:31 PM
96_4wdr's Avatar
96_4wdr
FORD dealer parts counter= Rip Off worse than Wall Street
Old Dec 18, 2008 | 03:11 PM
Aeroman59's Avatar
Aeroman59
Autolite makes plugs for Motorcraft, Autolite is apparently a Honeywell company!
Plugs to get are PP or double platinum. The Motorcraft version for our 3L vans is AGSF32FM. Conventional platinum plugs are not recommended. they will of course work, but servicable life will be reduced quite substantially. Looking at my records I recently paid $36 CAD inc tx, for a set of 6.
Aeroman.
Old Dec 18, 2008 | 04:36 PM
96_4wdr's Avatar
96_4wdr
the 95 3L Aero engine is conventional distributor not EDIS thus does NOT require double platinum. saves a few bucks
AUTOLITE Part # AP104 More Info {PLUGS Platinum}
Original Equipment Style; Gap .044; Replaces AP764
MOTORCRAFT Part # SP493 More Info {Platinum Spark Plug #AGSF32PM, AGSF32PMF4, AGSF32PMF6}
.044 Gap
about $2.50 each at Rock auto
Old Dec 18, 2008 | 04:53 PM
Aeroman59's Avatar
Aeroman59
Wonder what's the diff between PM & FM plugs ? I got the FM's from my local Ford stealership!
P.S. just found out FM means Fine wire, full threaded plug (which is also a double platinum).
(95, 3L) MOTORCRAFT® FULL LINE CATALOG OF PARTS FOR FORD, LINCOLN OR MERCURY VEHICLES
