power braking
Old Aug 11, 2001 | 06:00 PM
slothshady's Avatar
slothshady
power braking
may sound like a stupid question but i dont know any of you guys so im not gonna worry about it!
ok i have the granny gear 4 speed with the 300 in a 77 250.
if for some reason i was wanting to power brake it should i use first or second gear?
Old Aug 12, 2001 | 06:25 PM
TallPaul's Avatar
TallPaul
power braking
A granny first is so low that I don't think you can use it for engine braking (what I think you mean by power braking) except perhaps below 5 mph. I would go with second, but at higher speeds 3rd.
Old Aug 12, 2001 | 06:44 PM
82F100SWB's Avatar
82F100SWB
power braking
And, low aint syncro anyway.....
If you are talking about roasting your tires, use second, low will break U-joints.....
Evan MacDonald
82 F100 FlareSide 4wd
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
SBC valved 66 240 head
Headlight Relays - Delanty Style
NP435(6.69 low)
NP 205
3.55 Geared ARB'd 9" & Trac-Locked TTB
31x10.50/15 Cooper Discoverer LT's
Old Aug 12, 2001 | 09:54 PM
brown 4x4's Avatar
brown 4x4
power braking
I think he's talking about doing burnouts. I'd use second, less likely that somthing would break as Evan said.
1986 F-150 4x4 300 I6 NP435
Old Aug 13, 2001 | 05:09 PM
slothshady's Avatar
slothshady
power braking
ok..... i tryed it in second and i got it revved kinda high... it didnt do anything
i tryed in first and it did it easy but the back end jumped up and down
Old Aug 15, 2001 | 09:00 AM
whittey's Avatar
whittey
power braking
Wheel hop is really bad for your rearend... Jolts the hell out of your gears and puts some nasty harmonics on your spring.
Definatley go for second gear. What do you mean "it didn't do anything"??? If you put your foot to the gas and your other to the brake, something will happen, either you'll move forward, your clutch will slip, or you'll light 'em up.
-=Whittey=-
Old Aug 16, 2001 | 07:25 AM
TallPaul's Avatar
TallPaul
power braking
So power braking is kinda like the old brake torque that some did to their automatic tranny cars, right? I didn't realize you could do that, but apparently you get rolling and then stomp the brake and accelerator at the same time? Guess it would work pretty good since the fronts are disk and the rears drum. I remember a kid in high school had unhooked his rear brakes so he could do super burns--filled the whole area in front of the school with a huge cloud of smoke. As for me, I don't want to be that hard on my truck, though I did get a couple chirps (300 I6 F150 1995) out of it by flooring it in first (no brake) right up to 3500 rpm. She really flew. Best way to squeel em is to start on loose gravel transitioning to pavement (or just get a 460 V8)! Easier on the driveline.
Old Aug 16, 2001 | 12:32 PM
larry derouin's Avatar
larry derouin
power braking
When I was young and foolish (wife says I'm still foolish....) I worked at McDonalds (back in the early 70's.) After closing and finishing up we'd dump wash water out back door (buckets full) and then get out cars for burn outs.
As I had a 60' falcon (144, 2spd auto) no one there thought it would do anything. I'd roll thru the wet spot and then back up into it. STOMP on brake and then floor the gas. Then back off the brakes (all drums) just enough for the rears to break loose. Count to five and then let loose brakes. Smoke the tires all the way to the street (really short lot!).
Front disks just don't have the static braking power a drum does. Never had a car with disks sit there, always moved.
Larry
Old Aug 17, 2001 | 03:58 PM
slothshady's Avatar
slothshady
power braking
-=Whittey=-
i mean it just sat there and the engine revved.... i think i mighta been hittin the brakes to hard
Old Aug 17, 2001 | 05:09 PM
82F100SWB's Avatar
82F100SWB
power braking
Your clutch was slipping, either it isn't engaging fully, or is on the way out, was your foot completly off of the clutch??
Evan MacDonald
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
NP435(6.69 low)
NP 205
Old Aug 18, 2001 | 03:32 PM
slothshady's Avatar
slothshady
power braking
yeah it was completely off the clutch
i revved it enough so it wouldnt die kept on the brake and eased the clutch out.. then i gave it more gas
Old Aug 18, 2001 | 04:21 PM
82F100SWB's Avatar
82F100SWB
power braking
[font size="1" color="#FF0000"]LAST EDITED ON 18-Aug-01 AT 05:21 PM (EST)[/font][p]Hmm, the clutch was definatley slipping, how's the linkage adjusted? Mine would break 'em loose with the worn out 10" stock clutch.. Try getting it moving a little bit in reverse, then drop it in second, rev it up some, and drop the clutch, mine would end up sideways if I did that when it was stock and 2wd.... Now, all I have to do is walk on it...
Evan MacDonald
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
NP435(6.69 low)
NP 205
Old Aug 28, 2001 | 11:33 PM
slothshady's Avatar
slothshady
power braking
[font size="1" color="#FF0000"]LAST EDITED ON 29-Aug-01 AT 00:40 AM (EST)[/font][p].
Old Aug 28, 2001 | 11:37 PM
slothshady's Avatar
slothshady
power braking
i have no idea about the linkage.... dont know anything about it
i dont have to be rolling backwards i can light em up if i just drop the clutch at a high enough rpm
Old Aug 29, 2001 | 09:12 AM
greenfordguy's Avatar
greenfordguy
power braking
WickedSharp
Jul 13, 2011 08:32 AM
Gear Up
24
Apr 29, 2010 05:45 AM
jerdeb
Jul 3, 2009 07:52 PM
CommrclDiver
19
Oct 19, 2007 07:05 PM
big block power
Sep 13, 2002 08:28 PM
