tachometer
Old Dec 6, 2007 | 02:07 AM
hawaiian-style's Avatar
hawaiian-style
tachometer
is it possible to put a 302 5speed manual engine and transmition with originaly no tachometer into a identical truck with a stock tachometer.where would the extra plug be on the body/harness and where to plug it in into the engine..or transmition???
learning in progress!!!
mahalo-thanx
Old Dec 6, 2007 | 02:14 AM
77bigblock's Avatar
77bigblock
All truck are wired for a tach. The only difference is the cluster.
Old Dec 6, 2007 | 02:24 AM
Skandocious's Avatar
Skandocious
77 is right, having a tach or not makes no difference to anything. A common mod for these trucks is to swap a tach'd cluster into your non-tach'd truck, while swapping your speedo/odo to maintain proper odo reading.
Old Dec 6, 2007 | 12:17 PM
hawaiian-style
alrite.you guys is the bomb.
aloha
Old Dec 6, 2007 | 12:32 PM
Virto's Avatar
Virto
HOWEVER
It is important to get a cluster for your year truck. Some years overlap but just because the cluster LOOKS the same doesn't mean it will work correctly. The cluster electrics were modified over a number of years, so for the least headaches and best results, stick with one from your specific year.
Also, there is a tech article under articles/specs that details the swap.
Old Dec 6, 2007 | 02:51 PM
dreo2003's Avatar
dreo2003
yea i know 92,93 are interchangable and 94,95 are interchangable. the 96 is all alone. i learned this stuff the hard way. i have a 92,93 tached cluster if anyone needs it.
Old Dec 6, 2007 | 02:54 PM
tomtoc's Avatar
tomtoc
how would we get the year info added to the current article. the article says to USE SAME YEAR, but wouldn't hurt to list compatible years
Old Dec 8, 2007 | 01:50 PM
GrimOne's Avatar
GrimOne
My Tach
Apparently I must be the odd one out on that... I have a 96 F-250 and my instrument cluster came from a 95 F-150 and mine has worked perfectly. Then again my truck is not ODB II either
miashley150
13
Aug 22, 2013 11:34 AM
randgraham
Jul 14, 2009 06:45 AM
ejpreston
2004 - 2008 F150
Aug 15, 2005 07:41 AM
Hopcraft
Modular V10 (6.8l)
Jul 17, 2003 08:42 AM
terragate
Modular V8 (4.6L, 5.4L)
Jan 4, 2002 04:41 PM
