Alright ya’ll, I’ll try to make this a short one. Coming home last night I decided to test the truck out at WOT on a back road, which I have never done to this point after all of my mods. From a dead stop without powerbraking I found two things/issues:
Shifting from 1 to 2 is lousy at best. There is a huge hesitation then a snap into second.
After performing these drag strip type antics, the truck now runs at about 75% which concerns me. I didn’t hear a pop or any strange sound that would lead me to believe anything is catastrophic.
Symptoms are:
I’m still a novice when it comes to the PSD; however, I’ve done some generic troubleshooting; i.e. inspect and retighten boots, check map line and boost line for leaks, etc. I need to check the system for leaks elsewhere and suppose I should do this by some sort of pvc rig? Also, I’m going to check the turbo for shaft play this evening. I am praying that the turbo isn’t trying to take one because the holidays are already hard enough without a 1500 dollar hair dryer. And finally, I'm going to change the fuel filter as I haven't changed it since I bought it this past Spring.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
One more little wrench in things, could an electrical issue be causing any of these symptoms?
I know about the 25# deal, but just two days ago it would pull that much harder as it pasted 25#. Now it falls fat on its face at 22-25 and barely reached 26.
Sounds like a boost leak to me. You can build a boost leak tester out of a few $$$ worth of parts from HD or Lowes (PVC coupler & cap, air hose nipple, other misc parts). Can't find the thread right now, but someone will chime in with it, I'm sure.
boost leak detector.....3" PVC coupling with a plug for one end.. a pressure gauge regulator from the air compressor rack..drill, tap and build...plugs in where the ccv is in the air intake tube
Me thinks your HPOP might not be keeping up with the oil demand that the PCM is calling for. it will set a code for a while and then when the PCM see's that the ICP has stabilized the SES light will go out.
Even though the SES light is not on the code should still be stored. check for codes.
Thanks. I'll take care of that this weekend. Would it be a smart idea to buy new boots? The truck is almost eight years old.
Originally Posted by nhill2090
also, you need to check your intercooler boots ... since you said low boost and smoke through the RPM range
Good call. It looks like the cold side boot on the intercooler has slipped about a quarter inch from full seat. I tightened it up. Thanks.
Would a boost leak cause the SES light to flash like it did?
This is the first time the SES light has gone off. I've had the DP Tuner for about a month and have been pretty hard on it from cruising speed. Although, come to think of it, I tried to put my foot through the floor board this time. Could be BD, could be.
Now the newbie really shines through...how do I check for codes?
You are going to need a code reader. The ones from auto zone or anyother big box auto store dont work. Auto Enginuity is an option but its $300 to $400. How close is Mike(Tenn01PSD) to you? if he is close then yall get together and have a 6 pack or two (but no driving) and check that puppy out.
it wouldnt hurt to buy new boots...it will run you close to $120-150 for 6 new boots and 12 new clamps, its worth it...i will be buying new ones soon
it could also help to take them off, degrease them and the intercooler tube real good, then spray hair spray inside of the boots before you put them back on. this helps them stay in place better
i figured that might be your problem once you said smoke through the RPM band. did it fix your problem
the SES light is probably semi-normal, i would have to agree its probably because your HPOP cant keep up seeing as you have an OBA and would make the overboost light nearly impossible
