rounded, rusted bolts
Old Dec 8, 2007 | 12:12 AM
  #31
Fomoko1's Avatar
Fomoko1
Ya, I know WD40 is flammable.....
Old Dec 8, 2007 | 07:05 AM
  #32
needhelp49's Avatar
needhelp49
wd 40 doesnt work for fishing anymore used to have fishoil in it but thay toke it out but i bet most of us have a can of it somewere mr proud48 i'm glad you got your bolts out
Old Dec 8, 2007 | 11:40 AM
  #33
Proud48f1's Avatar
Proud48f1
Me Too!! I now have the whole body off, motor and trans out and even found out why it was parked by the PO. I pulled the valve covers and found the tip of a vale with the retaining clip siting there. hope the valve didn't do too much damage to the pistyon or cylinder wall, I'd like to at least have it for a core.
Old Dec 8, 2007 | 03:36 PM
  #34
economan's Avatar
economan
wd sure will do a number to lock cylinders, dunnoo how many cylinders i've changed on customers cars, the solvent action of washes the proper lube outta em' & just turns em' to white powder.
mikie
near ottawa canada
58 merc 10 panel, 64 econo p/u
Old Dec 10, 2007 | 10:27 AM
  #35
irondragon79's Avatar
irondragon79
One trick that has worked for me to loosen rusted bolts is one I read in an old truck magazine a while back (can't remember which though, its been a while). But heat up the nut to near red hot and then rub paraffin wax on it (yes, the stuff used for canning and candle making). The melted wax quickly penetrated the rust and acts as a lubricant for the metal and anytime I've tried it the bolts turn right out. Only problem is that if you not careful the wax may ignite, so wear gloved when your doing this... I've only had a few "small" fires...
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Jul 26, 2010 03:57 PM
Greywolf
Appearance & Dress-Up
Dec 28, 2009 11:42 PM
Greywolf
General Automotive Discussion
57
Jun 6, 2009 11:06 AM
oldusedbear
Modular V10 (6.8l)
Jul 23, 2008 11:43 AM
flaireside95
1978 - 1996 Big Bronco
Mar 21, 2004 09:38 PM
