need help getting more boost
Old Dec 5, 2007 | 08:53 PM
64ponton's Avatar
64ponton
hello pocket. is 12psi with the red line off bad for a 2000 with a programmer and do you think i have a problem.
Old Dec 5, 2007 | 09:06 PM
64ponton's Avatar
64ponton
thanks for your info izzy.
Old Dec 5, 2007 | 09:08 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Yah with that low of boost I think you have a leak some where. Just do what strokin_it7.3 said and get some gauges so you can see what is going on
Nick
Old Dec 5, 2007 | 09:12 PM
64ponton's Avatar
64ponton
ok thanks how much boost should a stock 2000 put out with the red line off
Old Dec 5, 2007 | 09:36 PM
Pocket's Avatar
Pocket
With a chip or tuner you should be pushing more than 20 PSI of boost at WOT.
Old Dec 5, 2007 | 09:41 PM
rbaker6336's Avatar
rbaker6336
when I had hypertec I could get about 27lb boost
Old Dec 5, 2007 | 09:42 PM
cangim's Avatar
cangim
where are you measuring the boost at? That may solve quite a few questions
Old Dec 5, 2007 | 09:57 PM
64ponton's Avatar
64ponton
reading from the red line side of the wastegate sensor
Old Dec 5, 2007 | 09:59 PM
64ponton's Avatar
64ponton
how much boost is to much on a 200,000 mile motor
Old Dec 5, 2007 | 10:01 PM
cangim's Avatar
cangim
are you taking the reading from the red line? i think that is what i am reading. There is a 1/4" line that goes from the y horn over to map sensor on the passenger side. This is most common spot to read boost.
Old Dec 5, 2007 | 10:15 PM
64ponton's Avatar
64ponton
that is correct the red line is this wrong
Old Dec 5, 2007 | 10:19 PM
cangim's Avatar
cangim
yeah, you want to take the reading from the map line, which is a 1/4" black rubber hose that has a split loom tubing around it. There are other ways to go about reading the pressure but the idea is to look at the intake plenum and read what is there. There is a MAP, manifold absolute pressure i believe, that is already doing this task, I placed a tee in this line and this is where I am reading the pressure from.
Old Dec 5, 2007 | 10:31 PM
  #28
64ponton's Avatar
64ponton
thanks guys talk to ya'll tommrrow
Old Dec 6, 2007 | 05:45 AM
  #29
ron's power stroke's Avatar
ron's power stroke
to the left in this pic you can see a dial (its my ITP OBA).it sits on top of the map sensor..my map line is red..yours will be black..one end goes to the spider..the other end goes to the map sensor..you need to tap into that black line for your boost reading..or you can get a AIH delete plug.tap it for a boost gauge like mine in this pic....
Old Dec 7, 2007 | 10:24 PM
  #30
64ponton's Avatar
64ponton
what is itp oba and what does it do?
