Ball missing in thermostat?
Old Dec 4, 2007 | 02:34 PM
Royson12's Avatar
Royson12
Talking Ball missing in thermostat?
I have searched the forums and found lots of info on changing the thermostat. Only problem is I can't find the check ball everyone is talking about. My engine is a 86 6.9. What is the significance of the ball? Is it ok without it. It has apparently been removed by a previous owner. I see the hole were it is supposed to be, but no ball visible. Should it be at the top of the hole, or could it be disquised with the antifreeze, where i can't see it? need to put this thing back togerther, please help. By the way I did purchase the factory thermo from ford to go back in.
Old Dec 4, 2007 | 04:12 PM
PLC7.3's Avatar
PLC7.3
The check ball is in the gooseneck (upper coolant manifold) what your probably looking at is the bypass hole in the block.
flysniper
1978 - 1996 Big Bronco
Mar 3, 2015 02:14 PM
blueheron
6.7L Power Stroke Diesel
Jan 3, 2011 06:18 PM
Mayne Man
Jul 23, 2008 08:51 AM
Greywolf
19
Jan 11, 2007 10:15 PM
bassaway
1983 - 2012 Ranger & B-Series
May 23, 2005 11:00 AM
