Sponsored by: Auxito
Misfire code P0302 on 97 E350 Van
Old Dec 4, 2007 | 09:41 AM
Magicman97's Avatar
Magicman97
Hello, I have a constant P0302 OBD pending code. Bought AutoEnginuity scanner. Ran scan and keeps coming up with a P0302 code, also notice when running scan that theres is ac fault in the Automatic ride control. Didn't thing that the Ford E 350 van has that feature. Put all new coil packs, injectors, new wiring harnes, PCM, adn fuel filter. Compression is same for all cylinders, used propane for test and had smoke test done. Ran good for about 50 miles then stated actin up again. Same code still. not sure what else to try. Oh forgot to mention 2 New O2 Sensors and took cat off to test with test pipe.
Old Dec 4, 2007 | 10:23 AM
chrisf250-460's Avatar
chrisf250-460
i assume you also changed plugs with the coil packs.maybe you have a bad wire,you could swap that wire with another to see if the code changes to another cylinder or a continuity test on the wire
Old Dec 4, 2007 | 10:28 AM
Magicman97's Avatar
Magicman97
Yes I replaced all 8 plugs with motorcraft plugs. These are COP no wires. All new boots and used Dielectric grease. Swap from cylinder to another still same pending code, no hard code or light. But it runs rough.
DANA60
Modular V8 (4.6L, 5.4L)
Jan 27, 2017 11:27 AM
butch h
Escape & Escape Hybrid
Nov 7, 2016 11:38 PM
gtmustang00
Jun 15, 2011 11:56 AM
soto8704
2004 - 2008 F150
Sep 28, 2010 10:21 PM
MrBookworm
Jan 28, 2006 09:47 PM
